First post, by DoomWarrior
- Newbie
hi
i want to install Pinball 3D/VCR but the installer claim there is not enough disk space. First i thought it could be the wrong size of my diskdrive (programm overflow after 2GB or so)
so i set this to 100MB. But without success.
So i recompile with debug stuff and start debugging (my asm-skills aren't the best)
after poking around a little bit it got THE funny thing
INT 21 (AH 1C)
the return value seems to be ok, the programm now checks
against 00F8 but the value is F8F8
i found some note in the internet
check_FAT: Unusual media descriptor (0xf0!=0xF8)
so the game find out it isn't a valid drive, if i understand the code correct, and skip C:\ (my drive)
so i Set register to 00F8 and now the installer work...
is this a 'bug' or did i miss some configuration ?
Bye
