First post, by oso2k
Has anybody compared the floppy bootdisk images from bootdisk.com (BOOT98SC below) and allbootdisks.com (BOOT98)? I, specifically, am concerned about the Windows98_SE_No_Ramdrive images (DOS 7.1). I noted differences in several files and the bootdisk.com image is also labeled "Custom, No Ramdrive". The bootdisks.com image is what Phil (from Phil's Computer Lab on YouTube) recommended. Obviously, I'm concerned about viruses and what potential modifications were made. Has anybody run AV scans, checksums, etc. against the images? Does anybody have an original CDs/floppies/images source to compare against? Does anybody have an opinion which is better? This isn't a critique against either provider, more, I want to document differences from originals and any fixes.
Thanks all...
>diff -u /Volumes/BOOT98 /Volumes/BOOT98SC/
Common subdirectories: /Volumes/BOOT98/.fseventsd and /Volumes/BOOT98SC/.fseventsd
Binary files /Volumes/BOOT98/COMMAND.COM and /Volumes/BOOT98SC/COMMAND.COM differ
Only in /Volumes/BOOT98: DISKCOPY.COM
Only in /Volumes/BOOT98SC/: DISPLAY.SYS
Only in /Volumes/BOOT98SC/: EXTRACT.EXE
Binary files /Volumes/BOOT98/FDISK.EXE and /Volumes/BOOT98SC/FDISK.EXE differ
Only in /Volumes/BOOT98SC/: FIND.EXE
Only in /Volumes/BOOT98SC/: IEXTRACT.EXE
Binary files /Volumes/BOOT98/IO.SYS and /Volumes/BOOT98SC/IO.SYS differ
Only in /Volumes/BOOT98: MTMCDAI.SYS
Binary files /Volumes/BOOT98/XCOPY32.MOD and /Volumes/BOOT98SC/XCOPY32.MOD differ
Reply 2 of 6, by oso2k
So that's my actual end goal. DOS on VirtualBox and modern hardware. But thanks for keeping me on topic.
collector wrote:
Note that this subforum is for DOS games on *modern systems*, not period hardware and OSs.
Reply 3 of 6, by Stiletto
Marvin is a better match for the time being. Moved.
If you're going to make a post about VirtualBox, "PC Emulation" subforum is where you want to be.
do the Fandango!" - Queen
Stiletto
Reply 4 of 6, by tayyare
No need to worry about improper customizations or virus issues. Bootdisk.com images are customized for users own comfort, nothing else. The same site also unaltered versions of the same boot floppy images, you can use them too, if you want. I used them numerous times without any ill effects.
Now I'm using my own "altered" images for booting, and I suggest you to do the same.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 5 of 6, by leileilol
One of them (Bootdisk.com likely) at least self-promotes themselves at boot, so don't reference that one if you're looking for authenticity.......
Reply 6 of 6, by oso2k
Thanks all!
