Nice idea.
I would prefer to utilize a SCSI optical drive enclosure though. They came with their own PSU and generally enough space for anything that you want to put behind the drive. Two examples are shown below:
The attachment DSC_028_zpsf8b8de8d.jpg is no longer available
If you are ok with an external power brick, USB optical drive enclosures are still available new:
https://urun.n11.com/dvd-ve-hdd-kasalari/ever … kutu-P180291938
I puchsed this recently for my own future external FDD Project (an external gotek box with both USB and floppy connectors 😊)
Instead of Kryoflux, maybe this one also works but I'm not sure if the circuitry supports 5.25 formats. (I have one and it works with 1.44 MB drives as expected). Converting the data connector should not be hard job using an old style floppy cable (with 5.25 type connectors) and some soldering.
https://www.aliexpress.com/item/USB-Cable-to- … .27424c4dBioNHh
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
