Reply 20 of 28, by EdmondDantes
- Member
So, everything is up and running, I installed Windows XP (SP3) and got everything set up the way I like.
By the way I should mention the specs at this point. They were in the ebay listing but some of them turned out to be wrong (in a good way) and that listing won't be around forever. So.
First the processor. It's a Pentium 4 which was sold as being 2ghz... turns out its actually 2.80! I don't know if that's overclocked or its natural speed (is there a way to find out?)
Least, I think its a Pentium 4. That's what the listing said, is there a way to be sure though? If it turns out I actually have a dual-core I may wanna trick this beast out a bit.
It came with 512 ram (2x256 sticks) loaded. I've looked up what kind of ram this board needs and thought of upgrading--apparently it maxes out at 2gb and can't detect higher. But I'm not sure if I need that power.
Of course, the graphics card is the Geforce ti4200 (AGP) and the sound card is a PCI Soundblaster Audigy 2 which may or may not be a ZS.
I've got two of those Audigies by the way, and I'm not sure what to do with the second one. Probably save it for a later comp because apparently the Audigy 2 was still a good sound card even well into last year. Oddly, neither Audigy has a joystick bracket--there's a spot marked for them but its got just a lot of holes, most of which look like they were filled in somehow? I tried to take a pic but I need a new cam, and.... I dunno how to upload pics to this forum either.
I'm not sure what other specs I should mention.
... So last night I tried to play Doom 3 on this thing. After installing the latest patch, the game ran okay-ish at the Medium settings at 800x600. At some points it felt like it would stutter (like if I load up the multiplayer deathmatch map with that spinning reactor thing and am in the room with it when it starts up).
It leaves me debating: Should I upgrade the RAM and video card and trick this board out, or should I keep its current hardware and use it as an early-XP/late-Win98SE dual-boot machine, and let "the ultimate Doom 3 machine" be a future project? For the moment I'm leaning towards the latter.
The only question left is, what to do about the case? Actual Dell cases seem like they're unsatisfactory--I'm very concerned about making sure my comps don't overheat (the first comp I ever had for myself developed problems for this very reason) so I'm thinking of buying a Thermaltake case and using sodder, bolt cutters, and ritual sacrifices to fit the motherboard in that. If you guys have any suggestions though, I'm open to them.
