Roland SC-7 serial midi
First post, by CornBrown
Anyone up to date with a good method for playing midi files in windows 7 w/ a serial to midi driver?
I know that selecting a default midi device has been removed from win 7 but i'm having a hard time even finding a good serial to midi driver.
I'm not really looking for "possible solutions" to try but if you've used a hardware synth to play midi's over serial, i'm all ears.
Reply 1 of 6, by Spikey
Even in XP I always had annoying issues trying to get drivers set up, or things working the way they should. Both with Roland and Yamaha synths. Always went back to regular MIDI cables.
Reply 2 of 6, by matze79
Roland Serial Out Driver should work fine.
Do you use real Serialport or a USB Cable ?
Reply 5 of 6, by CornBrown
Kamerat- this works great thanks!
