First post, by Vipersan
So ..My first ever Gotek arrived ..
FDD connection type.
but TBH I dont understand how this even functions at a basic level.
Does it come blank with no firmware installed ?
I connected it in place of my mechanical A: drive ..
Yes the three digits illuminate ..
Yes when I plug in a USB stick the gotek appears to know there is a USB stick ..
..the LED dots between the digits light up ..
I have installed usb_floppy_emulator_1.40i ..downloaded from Phils site ..
I figured this would be straightforward ...
not for me it isn't...
running XPpro atm
I go to format the usb stick ..using the above software but ..
the USB stick isn't even in the list so no format possible ?
what am I doing wrong ?
This unit did not come with any instructions at all ..?
So I am bewildered.
Can someone who uses one kindly illuminate my darkness ?
rgds
VS
Reply 1 of 8, by tannerstevo
To format the USB stick plug it into a USB port, not the Gotek.
The gotek only reads the usb stick.
the software is used to write to the stick so the gotek can use it.
Reply 2 of 8, by root42
Na, the Gotek can format the stick. Press some buttons during power up, IIRC.
But to be honest: the vanilla firmware is not the greatest. However there is this:
https://github.com/keirf/FlashFloppy
I haven't installed it yet but will do so in the coming weeks...
YouTube and Bonus
Reply 3 of 8, by tannerstevo
root42 wrote:
Press some buttons
Very helpful. 😵
Reply 4 of 8, by root42
tannerstevo wrote:
root42 wrote:
Press some buttons
Very helpful. 😵
I haven't used the gotek for a few months. And I formatted the stick only once. Try pressing both buttons and then power up. It should quickly count up to 99 or 100.
YouTube and Bonus
Reply 5 of 8, by Vipersan
Yep ..
sort of figured it out myself ..
I assumed I could write a floppy image through the Gotek..and as has been pointed out ..
Not possible ..at least not with usb_floppy_emulator_1.40i
The PC I was using doesn't even have USB ports ..so nipped over to my win7 PC ... installed the software on that ..
Formatted the stick ..and put a win98se boot floppy image on OO..
back downstairs with the stick ..and the PC with the Gotek ..booted from it no problem.
thanks guys ..
but I guess everyone has to start somewhere with something new..
(insert red face here ..🤣)
..that said if it is possible to write floppy images through the Gotek with different software ..that would be very useful in this case.
rgds
Reply 6 of 8, by tannerstevo
Glad you got it working.
And root42, sorry did not mean to be short with you, I have just had a very bad day at work.
Reply 7 of 8, by root42
No worries.
And else, I can still declare you a foe in the system. 🤣
YouTube and Bonus
Reply 8 of 8, by tayyare
Vipersan wrote:
Yep .. sort of figured it out myself .. LOL I assumed I could write a floppy image through the Gotek..and as has been pointed ou […]
Yep ..
thanks guys ..
rgds
- You can copy all your images one by one: After formatting your flash drive (i.e. by pressing two buttons together while powering up your Gotek), chose the appropriate "slot" on the Gotek (i.e. 000, 001, 002, 003,......999) and use a diskcopy sofware of your own choise to transfer the image files into your flash drive. Very tiresome and loooong process.
- This floppy emulator sofware that you are trying to use is ok for writing images to your Gotek formatted USB flash drive. It is ok for only a 100 images though.
- Use the instructions and batch files there: https://github.com/xtcrefugee/gotek-usb-batch-files
- Use the procedure here to change your Gotek's firmware with "flashfloppy" (and your 7-segment Gotek display with an OLED display while you are at it), and just copy all the images into a common normal format USB flash drive: https://github.com/keirf/FlashFloppy
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
