Intel overdrive dx4 100 running at only 75mhz
First post, by treeman
So recently I pulled out a old 486 isa board CHICONY, INC.
CH-486-33/50 L with a dx50 chip running 50fsb stock
After identifying the board I decided to drop a dx4odpr100 in there and set the fsb down to 33.
On startup system shows as 66mhz but in benchmark utilities (tried 2) shows as a dx or dx4 75 mhz
To it seems as if the cpu is running at 25 fsb 3x25 = 75 instead of the 3 x 33 = 100 as designed
The weird thing is this board has a jumper for 50fsb or 33/20 so not sure how it knows I want 33 not 25
Maybye somebody has good knowledge of this board and has a idea?
Also here is my thread about identifying the board with pictures and also about the cpu
Help identify this 486 opti motherboard
Reply 2 of 24, by treeman
I found out its indeed running at 25 fsb. I don't know about the fsb crystals. Does that mean I have a 50 crystal so it runs at 50 or 25? So if I want 33 fsb what crystal would I need?
This is from the manual
CPU SPEED CONFIGURATION
Type
JP12
20MHz
pins 2 & 3 closed
25MHz
pins 2 & 3 closed
33MHz
pins 2 & 3 closed
50MHz
pins 1 & 2 closed
Reply 4 of 24, by kixs
Can you run Speedsys and post screenshot? I'm wondering about L2 cache on the motherboard.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 5 of 24, by jesolo
Kamerat wrote:
Maybe you'll need to change the clock crystal, is it socketed?
Edit: Had a look at the pictures, the crystal is clearly a 50MHz one and it's socketed.
I agree with this.
Jumper JP12 makes provision to either run at full speed of the clock crystal or by a divider of 2 (in this case, either 50 MHz or 25 MHz).
If you do swop out the crystal for a 66 MHz one, then I would not recommend you try to set JP12 in the 1-2 position, as you would then be running your FSB at 66 MHz.
Reply 6 of 24, by treeman
Ok great thanks for explaining it to me, I will look around for a 66mhz crystal
Here is some screens of cache info, sorry not the best quality pic
Yes I will definitely keep it at half rate not interested to see what happens at 50 or 66mhz
Reply 7 of 24, by shamino
I don't know anything about this board, but based on what's been said, it might be more useful to get a 33MHz crystal. That way you'll have a usable slowdown option.
Reply 8 of 24, by kixs
L2 cache looks fine.
Reply 9 of 24, by treeman
This is the first time im learning about crystals so it's all new to me, but if there is a 33mhz one I think that makes more sense to me too since I will never need or want to use 66mhz, unless there is more to it.
The only overclocking I did was on Slot1 and socket 370 in the past which were all bios controlled
Reply 10 of 24, by kixs
You need 66MHz crystal as the frequency is divided by 2. At the moment you have 50MHz one and you get 25MHz bus. With 66MHz one you'll get 33MHz bus. Your DX4 needs 33MHz bus to run at 100MHz.
Reply 11 of 24, by treeman
If you mean bus the fsb the cpu runs it came initially with 50mhz and a 486dx50 cpu which I believe runs at 1x50mhz but I changed the pin and now its running at half fsb 25 so 3x25 but for my dx I want the 3x33=100
However this also gets me thiking what about the isa and ram? If I get a 66mhz crystal and run it at half speed or a 33mhz crstal and run it at full speed will it the same system wide? Because like mentioned before a 33mhz crystal running at full speed can still be set to half through jumpers, probably not useful at the moment, however a 66mhz chip running at half will never be useful to me running at full speed of 66mhz
This is my reasoning and logic after 5 minutes of learning about crystal oscillator
Edit: ok so looking for the part they don't seem to be too popular so I think ill settle on 33 or 66 whatever is easier to find as long as they will both work the same with half clock and full clock respectively. Mine is a koyo kco-110s
Do you guys know if can replace with another brand or better stick to same one?
Reply 12 of 24, by fitzpatr
The oscillator will always generate the same frequency. I believe that the motherboard has a jumper (25/33 or 50) which will either halve it, or use it at full speed. This is used to set the bus speed. As an example, with the jumper in 25/33, the 50MHz oscillator signal is halved, giving you a 25MHz bus (50MHz/2). The Intel overdrive, despite the "DX4" name, has a 3x multiplier. Therefore, it operates at 3 times the bus speed. In this case, 25MHz x 3 = 75MHz. It seems that the only way to alter the bus speed up to 33MHz is to replace the crystal oscillator with one double that of your desired bus speed.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 13 of 24, by treeman
Ok, thanks for the more details.
So on my board I have a jumper setting for 50mhz or 33/25
So then best to get a 66mhz crystal and set the jumper in the 33/25 position?
Can I use this one?
https://au.rs-online.com/mobile/p/crystal-osc … lators/4785941/
Reply 14 of 24, by fitzpatr
I think that I gave you slightly incorrect information. I shall amend my post above, but re-iterate here.
I think that the 25MHz/33MHz or 50MHz jumper could actually be what cuts the oscillator in half. 50MHz bus speed does exist.
Nevertheless,
Should still be correct.
I expect that this made it easier to use the same motherboard with SX-25, SX2-50, DX-25, DX2-50, and DX-50 all with the same oscillator crystal.
What you're looking for is a DIP-14 66.000 MHz oscillator. I don't think that the one you've linked is compatible. If you have any desire to run at a 40MHz bus, then you'd want an 80MHz crystal.
https://www.ebay.com/itm/401181050200 is what you're looking for.
486 Build
Reply 15 of 24, by treeman
Great thank you for the explanation and solution for me!
I will order the part you linked, 80mhz is also tempting which would give me 3x40 =120mhz, something to think about in the future for now I will first get it going at 100mhz
Will take a week or 2 since im in Australia but Ill make a update when I get the oscillator
Reply 16 of 24, by Scali
That is correct. There are two variations of 486 that run at 50 MHz. The first ones were regular DX50 CPUs, with the bus at 50 MHz. As it proved troublesome to run the entire bus and chipset at 50 MHz, Intel later introduced the DX2-concept, which launched the DX2-50, running at 25 MHz FSB, and the more familiar DX2-66, running at 33 MHz FSB.
So if you have a DX50, it will indeed run at 1x50 (or 1x25 if you set the jumpers to halve the clockspeed).
Reply 17 of 24, by treeman
Ok the crystal that fitzpatr linked came, I fitted it and running at 99mhz so mission success.
In the meantime I also localized a Kingston turbo chip 586 133 which is a 586 in a 3v to 5v convertor. Which is supposed to run 4 x 33.
So Kingston went in next but looks like 116mhz is the fastest this board will go, I read this before on a different thread.
Also I think only 100mhz is being used because 116mhz
586 Kingston turbo chip got exactly the same score as intel overdrive at 99mhz
So quiet happy with this result pushing the max from a 486 isa system is what I wanted, thanx for all the contributions
Reply 18 of 24, by Anonymous Coward
It sounds like the Kingston turbochip may be operating in 3X mode. You might need to change a jumper in order to get it to run in 4X mode.
As far as I know, the Kingston Turbochip won't really be any faster than the IntelDX4 even at 133MHz, due to the DX4's superior design (only applies to intel dx4s). However, if you get the 80MHz oscillator, there is a good chance that the turbochip can overclock to 160MHz, which would be a worthwhile upgrade.
Reply 19 of 24, by amadeus777999
The TurboChip I own has a fixed 4x multiplicator - are there any variants with dip switches?
Mhz numbers shown in combination with the Cyrix string in SI are usually incorrect.
