First post, by Intel486dx33
Hello, I am asking for advice about some Super Socket 7 builds.
I have 4 of these Super Socket 7 motherboards so I can do various builds. They are like NEW. I think they are system pulls from computers that were never used.
They are in ESD antistatic bags and don't have any signs of use on them.
Purpose: To be able to play as many old games as possible, DOS time machine.
I would like them to perform optimal. I don't want to over load the computer CPU.
I was inspired by Phils build.
https://youtu.be/9CgisEFObjA?t=1294
But I don't want to use a Roland MT32 & MPU-401 Midi interface as I don’t have one.
Just the sound card. Do I need one ?
Components I have.
They are the Baby AT, Super 7 motherboards. They have USB, PS2, AGP, etc.
Soyo SY-5EHM v1.1
VIA Apollo MVP3 & VIA Apollo VP3 chipset
IDE controllers.
Award Bios
AGP, PCI, ISA slots
Up to 256mb. ram
Y2K compliant
PC98
2.0v - 3.5v CPU
Up to 500mhz CPU.
Currently, they came with a Pentium 233mhz CPU and 256mb ram.
Supported CPU's
Intel pentium
AMD k6 2/3 up to 500mhz.
Video
I have a Voodoo 3 3000 AGP
Matrox AGP cards
Nvidia AGP cards
ATI Rage 128 Pro AGP cards
Audio
Sound blaster Vibra 16
Yamaha OPL Audician 32 Plus
Sound Blaster AWE64
Sound Blaster 5.1 PCI
Sound Blaster Audigy 2zs
Hard drive
Conventional IDE 72000rpm ( Seagate )
IDE to Sata adapter with SSD ?
CF card
Operating systems
Multi boot
DOS
Win98se
Case
LIAN LI PC-8NB
Antec VSK4000E
floppy drive
cdrom
etc.
Reply 1 of 6, by Repo Man11
My advice is to replace the capacitors since the ones near the CPU look domed.
Reply 2 of 6, by Intel486dx33
I just opened up all the sealed ESD antistatic bags and inspected all the motherboards. They look NEW with no dust or markings or signs of use.
Only one motherboard has bulging caps. It's an easy fix. Not a problem.
Reply 3 of 6, by chinny22
If this is your only PC
Video
Voodoo 3 3000 AGP - Good dos compatibility and Glide for Win98, Only Negative is is D3D games
DOS sound
Sound Blaster AWE64 -Basically a SB16 with clean output, As you dont have a Midi device the AWE will give you better midi then the other cards. Possible Negative, not true OPL chip.
Windows Sound
Audigy 2 zs, Better then the Live in every possible way.
HDD
Just go with the seagate for now.
Case, whichever works best
test the system out and work out if it has any weak points. It'll mostly come down to which games your playing and personal preference.
It may be the system runs too fast, or slow in which case you can get the correct CPU for your needs accordingly.
If you play a lot of really early games with adlib the CQM may bother you and you can swap out for the Yamaha card (and loose SB16 and AWE support) or you may not need it at all.
Reply 4 of 6, by gdjacobs
1) Is there a jumper header or BIOS option for setting FSB and multi on any/all of these boards?
2) Do any of these boards support 50mhz FSB?
3) I take it your P233 is a P55C MMX chip?
If the answer to these questions is yes, I'd look at making a Ludicrous Speed Pentium MMX time machine that can be clocked down to around ~100mhz and up to 300mhz with 100mhz FSB. With cache and branch prediction disabling, you'd be able to achieve slow 386DX performance with lots of performance options all the way up to Pentium country.
Reply 5 of 6, by Intel486dx33
gdjacobs wrote:
1) Is there a jumper header or BIOS option for setting FSB and multi on any/all of these boards? 2) Do any of these boards suppo […]
Do you mean a setup like this video?
https://youtu.be/fcAqRbFFQPU?t=630
Reply 6 of 6, by Intel486dx33
Update:
So I think I am going to go with
K6-2 3+ CPU @ 500mhz.
256mb ram PC-133
Voodoo-3-3000 AGP with modified larger fan.
Conventinal IDE 72000 rpm hard-drive ( Seagate )
Sound Blaster Live 5.1 PCI with live drive
Slot loading Sony CDROM
IDE DVD Sony
250mb ZIP drive
10/100 Network adapter.
Floppy drive
IDE controller. ( Promise, iWill, or High point )
PS/2 keyboard with laser mouse.
Lian Li case
