First post, by DOSfan1994
I trying wanting to watch movies on XingMPEG player on my Windows 3.1 VM I made on PCem. The software opened fine. But when I was trying the "Test.mpg" file the video quality was chopy and not really smooth at all.
What should I do to fix this problem. I only turned off the Dynamic recomplier so my DOS games will play better when playing it from Windows 3.1 how I played them back when I was young.
It worked fine when I had the Winchip or Pentium set to 200 with the Dynamic recomplier on. But I want to watch my movies and play DOS from Windows 3.1 games on my PCem Windows 3.1/DOS VM.
If you know a trick whether if it's the emulator or inside Windows 3.1 to fix this problem I would like to know.
My windows 3.1/DOS host PC specs
Machine: Award 430VX PCI
Processor: Winchip 75mhz (Dynamic recompier off)
Soundcard: Soundblaster 16
Video card: Tseng ET4000AX
Memory: 256 MB
Reply 2 of 3, by leileilol
"i turned off the speed feature and now it is slow. why is this happening. help"
Debian's fucked
Reply 3 of 3, by tpowell.ca
DOSfan1994 wrote:
It worked fine when I had the Winchip ... with the Dynamic recomplier on.
Problem solved.
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
