First post, by cxm717
OK, so just as the title says I'm getting really bad flickering on my nvidia TNT when I disable vsync in D3D.
The card is a Creative CT6710 and everything seems to work with vsync enabled and OpenGL is fine with it enabled or not. I have the card in an Aopen AX6BC (Edit: the board is an AX6BC, not AXBC) with a P2 450 and 128MB of PC100. I also have an SB live and SB16 in the board. The games I get the flickering in are incoming, forsaken, turok and turok2. I have tried drivers 21.83, 40.72 and 44.03.
I made a quick video of the problem with my phone: https://youtu.be/vNfnuHiMOjA
Reply 1 of 7, by spiroyster
The purpose of vsync is stop flickering (by syncing the gfx card refresh with your screens refresh) so I guess it would make sense that you see flickering when vsync is disabled. OpenGL perfromance probably isn't as good as D3D so doesn't render at framerates that exceed you screens refresh rate, ergo you might not need it enabled with GL, but do with D3D.
Reply 2 of 7, by cxm717
Well, when I disable vsync on my other cards it sure doesn't look like that. Sometimes you can see through objects/walls. Maybe someone with a TNT card could give it a try? btw, powerstrip does not disable vsync on the newer drives, only rivatuner worked. I ended up trying some older drives, 5.32 and 8.05 and they were the same.
Reply 3 of 7, by spiroyster
Yes, seeing through objects and walls doesn't sound like a vsync issue o.0. More a driver issue maybe? Or it could be a combination of driver and/or hardware slightly malfunctioning.
Pausing your video at various points seems to display the same issue you mentioned, some geometry seems to be left out when rendering in alternate frames? there is slight tearing too. Its seems quite screwy with dropped geometry and the refresh is obviously bang out of sync with what it should be. Is double bufferuing enabled? I don't have a TNT set up so can't test anything for you I'm afraid. Is there any reason you want vsync disabled?
Reply 4 of 7, by swaaye
I'm sure I've heard of this problem before. Sounds like a buffer problem.
Some results here:
https://groups.google.com/forum/#!search/tnt$ … vsync$20tearing
Reply 5 of 7, by F2bnp
Can you try a much older driver and see if it produces the same results?
These are from 2000 and run even on a GeForce2, so give them a go.
http://vogonsdrivers.com/getfile.php?fileid=7 … &menustate=14,1
Reply 6 of 7, by cxm717
Ok, I got it working normally. I went through all the Nvidia drivers in the vogons driver library and the detonator 2.08 drivers work. I noticed the rivatuner vsync page changed with different drivers. With 2.08:
102.59 KiB
and with 45.23:
101.59 KiB
Reply 7 of 7, by cxm717
Some results here:
That's interesting, I'm not the only one to have the same problem with newer drivers.
I just wanted vsync disabled so I could benchmark the card and compare the results with other cards.
