Reply 20 of 24, by treeman
The only pins on the turbochip is a dx/sx setting, I was curious about this and downloaded the pdf instruction and weird nothing about the sx/dx pins. But about 4 pages on how to safely remove the old cpu.
I set the pin on DX, however now im thiking Maybye try SX.
But 116 is a weird number if it was on 3x multiplier I think should show 99mhz exactly like the dx4 overdrive.
I read a thread a while ago about some guy that was trying to oc a old 486 board and was also stuck at some odd mhz reading.
Unless it is a total coincidence and a 586 running at 116 mhz gets exactly the same score as a dx4 running 99mhz. As you say about the readings being correct.
Anyhow I will be on the hunt for a 80mhz crystal as yeah apparently the 586 are very overclockable.
