First post, by twiz11
Or is it by case basis?
Reply 2 of 5, by Davros
not a vm but a live dvd knoppix
has nvidia and amd drivers and wine
just boot into it and play the games installed on your hard drives
Reply 3 of 5, by ZellSF
If you want anywhere near good compatibility you want PCI-e passthrough and for that you need a dedicated GPU. It's also pretty complicated to set up.
Reply 4 of 5, by leileilol
That's all a dream theory until you run into mouse input issues with VMs.
Debian's fucked
Reply 5 of 5, by ZellSF
No mouse input issues if you passthrough the USB port to the VM. You'll probably need a KVM. The best solution isn't cheap either.
