Matrox G2+ What Type Of Memory Does It Need?
First post, by GabrielKnight123
I bought 3 Matrox AGP video cards that have "Matrox 834-00 Rev A" and on the back sticker is "G2+/SDA/8BF/20" it looks very like this card except for the memory chips mine has four of them instead of two:
What type of Ram can I use in this card and what would be the max amount? In the Matrox G200 wiki is this line:
The cards also had ports for special add-on boards, such as the Rainbow Runner, which could add various functionality. - What are these add on boards as in what do they do and is it worth while getting one?
Reply 1 of 24, by Rawit
If you have 4 memory chips and if those chips have pins on 2 sides instead of 4 sides as pictured, you need SDRAM for your cards, 8MB max. Normally AGP cards use SGRAM.
YouTube
Reply 2 of 24, by Errius
Which is better, SGRAM or SDRAM?
I heard this upgrade is pointless for games, and only useful for bigger Windows desktop resolutions. Is that correct?
I remember trying to run 3DMark2001SE on a 8MB Millennium G200 and being unable due to lack of memory. Does the upgrade allow this to be done?
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 3 of 24, by appiah4
SGRAM is better but you can't mix and match.
Extra 8MB would probably make no difference for a card as weak as the G200, it's roughly about as fast as an i740.
Reply 4 of 24, by Rawit
No, 3DMark2001SE requires 32MB of video memory.
YouTube
Reply 5 of 24, by GabrielKnight123
Ok I will find some SDRAM but dose it matter what speed it runs at or can all speeds work?
Reply 6 of 24, by appiah4
You don't want to go buying SDRAM, you want to buy special SDRAM modules made specifically for that connector. They are not very comon.
Reply 7 of 24, by derSammler
Sound like an OEM version with standard DRAM. I own one of these as well.
Reply 8 of 24, by GabrielKnight123
If I take a picture of the ram slot can someone tell me what it needs?
Reply 9 of 24, by derSammler
Of course.
Reply 11 of 24, by GabrielKnight123
Im having second thoughts that it will not be of any benefit plus the price would be to high so I will keep them just as they are, thanks for all the info.
Reply 12 of 24, by Errius
Is it really worth chasing these upgrades? What difference do they make? Do any important games need them to run? If the advantage is just higher Windows resolutions/color depths then there's little point to them.
Reply 13 of 24, by appiah4
No, I would completely skip getting the extra 8MBs. For the same money you can probably just get a Matrox G400/450.
Reply 14 of 24, by GabrielKnight123
I agree Errius but on a good note when I saw these cards I thought they were like an AWE 64 so I grabbed them with high hopes but I guess this card is better than an S3 Trio 3d as ive read bad things for the 3D side of the S3 Trio 3D which I bought as well with the 3 Matrox cards.
Reply 15 of 24, by Standard Def Steve
3DMark01SE runs on 16MB Voodoo3 and TNT cards. Still, I can't guarantee that it will run on an upgraded G200, since the GPU itself might not be supported.
"A little sign-in here, a touch of WiFi there..."
Reply 16 of 24, by Rawit
Just found out that VGA Museum has a YouTube video up showing the Matrox G200 running 3DMark2001SE. So the 32MB video memory requirement I read about is most likely not the case. But I can't see if they are running it stock or with added memory.
@Errius How much RAM do you have?
BTW, I have a Matrox/Compaq SGRAM (not SDRAM) module here, NIB, not using it. If you're interested, PM me.
YouTube
Reply 17 of 24, by Errius
I ran the 3DMark2001SE test on a computer with 256 MB RAM. It was an AGP card if that makes a difference.
The SGRAM modules (G2+/SG/MOD8) appear to be more common than the SDRAM.
Reply 18 of 24, by Errius
Old webpages:
https://web.archive.org/web/20000621005044/ht … color_depth.htm
https://web.archive.org/web/19990427081808/ht … em_upg/home.htm
Here Millennium G200 is the SGRAM model and Millennium G200 SD the SDRAM model.
Reply 19 of 24, by swaaye
I think adding RAM reduces memory clock speed. That would be undesirable. 😀
