Mouse axis sensitivity
First post, by LordJimbo
Is there a way to change the sensitivity of the mouse in just one axis?
Example: The Full Throttle mouse seems to be fine along the x (horizontal) axis and way too sluggish in the y (vertical) direction.
Can I change one without changing the other?
-Jim
Reply 1 of 7, by Guest
has anyone come out with a solution for this? I have noticed the mouse is about half as sensitive vertically as horizontally, but posts seem to have stopped about it. can anyone point me to a solution here?
Reply 2 of 7, by HunterZ
Have you tried a recent CVS build? (check the development forum for info)
I remember this happening in Full Throttle and Arena as well. Don't know if it still does or not.
Reply 3 of 7, by `Moe`
Due to pure coincidence, I noticed a change in the mouse code in today's CVS checkout. Someone (qbix, I guess) modified the Y-resolution for certain cases during the last few days. You should try a CVS build of today or the next one that's available. It might fix the issue.
Reply 4 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
well there were a lot. but I think you refer to a change made by wd. (if(useps2callback) dy*=2;)
Although It's also possible that the positioning code changes, I made, help. (as those fixed arena)
Water flows down the stream
Reply 5 of 7, by wd
Rank DOSBox Author
DOSBox Author
This only affects windows, did not encounter any game that uses
the ps2 interface directly.
Reply 6 of 7, by HunterZ
So the emulated mouse in DOSBox is PS/2 with the standard (Logitech?) TSR driver interface also emulated?
Reply 7 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
well I think we claim to be a Microsoft mouse driver clone. version 7 or 8
DOSbox reports to have ps2 mouse although all games use the mouse driver interface so it shouldn't matter.
Only windows tries to use the ps2 interface so that has to be emulated additionally.
(quite fun actually. in a real pc. the mouse driver uses the ps2 ports or bios interface to create mouse. In dosbox it's the otherway around. 😀 )
