First post, by eL_PuSHeR
Updatedon October 2005
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 1 of 5, by HunterZ
Damn, you got my hopes up for second. I use nVidia's drivers on my nForce2 board, but I can use the Realtek drivers instead if I want because it has a Realtek ALC655 chip on it. I tried this exact version (A3.77) last week and found that the EAX support was buggier than in the nVidia drivers, so I switched back.
Reply 2 of 5, by [vEX]
Do I dare try them? I tried the updated drivers from Windows Update once and that killed my sound pretty good, had to rollback the driver to restore it. Or are these drivers only for the newer chips?
Antec P182B | Asus P8Z77-V PRO | Intel i5 3570k | 16GB DDR3 | 4TB HDD | Pioneer BDR-207D | Asus Xonar DX | Altec Lansing CS21 | Eizo EV2736W-BK | Arch Linux (64-bit/x86_64)
Reply 3 of 5, by HunterZ
These drivers are for the whole ALC series I think. You can check the readme to see what's supported.
Reply 4 of 5, by eL_PuSHeR
It seems to work fine for me on my ALC650 (nForce2) rig.
@HunterZ:
I do not use EAX but the surround test seems to work fine. I have played some games without problems.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 5 of 5, by HunterZ
3D positional (surround) sound in games is usually done in DirectSound3D. EAX is a set of extensions to DirectSound3D that I haven't seen any good tests for.
Also, v3.78 is out but Realtek hasn't updated their readme, so I can't tell what's new yet. I think I filed a bug report with them so there's a small chance they fixed my EAX issue:
http://www.realtek.com.tw/downloads/dlac97-2. … 8&Software=True
