First post, by GabrielKnight123
I have a Am5 x86 -P75 AMD X5 133ADZ Cpu with about 32mb Edo Ram and I would like to use an Nvidia Geforce FX 5500 256mb PCI video card but I bet that would mean I couldnt use the 250W power supply I would have to use an adapter with a newer ATX power supply at about 300W +, is this correct so far? Has anyone done this with similar hardware?
Reply 1 of 3, by ODwilly
You should be fine with a 250. Most systems that era use the 5 and 3.3v rails over the 12v and have plenty of room for extra power hungry peripherals. In fact alot of 150 or so watt power supplies powered 486 rigs of that era. EDIT: Also at max a pci slot can draw 25 or 30 watts. So you figure that plus a 30watt cpu at maxish, plus hard drive, optical drives, ram. Lets say 10 watts per drive, two of each. plus another 10 for fans ect. You got 110 watts. Now, most of that is going to be on the old 3.3v and 5v rails, ya got an old psu balanced for a measly 3 or 4 amps on the 12v rail and something like a 486 or early Pentium is going to work great. The important part is quality, system component selection, and rail amperage.
Reply 2 of 3, by The Serpent Rider
GeForce 4 MX PCI will work with a 486 motherboard.
Reply 3 of 3, by Standard Def Steve
The FX-5500 probably requires a newer revision of PCI than a 486 board has. And even if you could get it to POST with the card installed, the Windows driver would probably require a Pentium.
"A little sign-in here, a touch of WiFi there..."
