First post, by superfury
I'm trying to diff two ~4GB text logs(common emulator logs) with diff, but it tells me "insufficient memory" and quits. Using kdiff almost immediately after opening the two files with a regex added to filter the results(to make it ignore all general purpose registers but ESP and EBP) makes the entire computer hang with 100% hard disk access time(mouse&keyboard unresponsive), requiring the computer's hard reset button on the computer case to reboot and make it responsive again.
Anyone knows something I can use to diff those files(-u format) with regex filtering(for the above-mentioned registers) without making the entire machine lock up?
I'm using Windows 10 64-bit with 8GB of RAM(also i7-4790K).
UniPCemu Git repository
