Sound Blaster Pro 2.0 Build ?
First post, by Intel486dx33
I was finally able to obtain the illusive Sound Blaster Pro 2.0 ISA card.
I want to build a PC around this card for best Audio experience.
I am asking for your recommendations as to what hardware I should use ?
I want it to endure so I am using some NEW parts too.
Best of both worlds NEW and old.
Motherboards - I have socket-3, Socket-7, Super Socket-7, Slot-1 with ISA slots.
CPU’s - I have 486-33/50/66, AMD K6-2-533, K6-3-450, pentium 166/200/233, Pentium-2 233/333/400,
Pentium-3 500.
Ram - I have 8mb to 512mb FPM or EDO.
Graphics - Voodoo-3 AGP, Voodoo-3 PCI, Banshe AGP and PCI, Matrox, ATI, S3 trio64 PCI, Oaktech ISA.
Audio - Sound Blaster Pro 2.0 and Yamaha YMF-7xx, ISA, Terratec Base-1 ISA.
Case - Antec VSKe4000
Power supply - Modern 450watt ATX with AT adapter.
Hard-drive - CF card with adapter or a 500mb Hard-drive.
SCSI controller - Adaptec ?
IDE controller - Gold , Winbond, UMC, Sony, Creative ?
CDROM - IDE or SCSI ? 4x, 8x, 16x, 32x, 52x ?
What do you recommend ?
Please leave your comments so I can build a good quality computer that will endure.
Reply 1 of 53, by bjwil1991
Just so you know, the SB Pro 2.0 requires the -5VDC (make sure the ATX to AT adapter has the -5V with the 3.3V dummy load).
Reply 2 of 53, by Intel486dx33
Okay, Yeah. I have some of those AT adapters with a dummy load.
Thanks.
Reply 3 of 53, by MMaximus
Correct me if I'm wrong but the SB Pro 2.0 doesn't require -5v. You might be confusing it with the SB 2.0 (CT1350B) which does require -5v.
Hard Disk Sounds
Reply 4 of 53, by root42
Can someone explain this dummy load thing? When is it necessary? How is it implemented? Simply a resistor? Something more advanced?
YouTube and Bonus
Reply 5 of 53, by tpowell.ca
Pretty sure an SB Pro doesn't require a -5v supply.
The dummy load is simply a low impedance resistor (5ohm 10W should do the trick) to satisfy some power supplies requirement of a minimum load on the 5v line to operate properly.
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 6 of 53, by root42
Ok, thanks. Sounds reasonable.
YouTube and Bonus
Reply 7 of 53, by Shagittarius
Personally I think the original sound blaster is the better audio experience. THe Sb Pro 2.0 sounds muffled to me. Is there any way to remove that muffled sounding filter from the SB Pro 2.0?
Reply 8 of 53, by bjwil1991
There is a way to disable the integrated amp, but, that'll require software to change the volume.
Reply 9 of 53, by tpowell.ca
Yes, the low-pass filter is software defeatable. I made a software mixer that can do that.
When I get home, I'll upload it here.
Reply 10 of 53, by Intel486dx33
Thanks people.
You learn something NEW every day on this website.
Any recommendations on what CPU, RAM and Operating systems work best for audio play back on this SB ?
Reply 11 of 53, by tpowell.ca
Here is the mixer I made a long time ago while learning about C programming and the Sound Blaster interface.
It requires a mouse to work, and I think it assume port 220h.
Sorry about the terrible look and crappy interface. I'll definitely update it soon as I am trying to resurrect my SB Pro card for my next 486.
Reply 12 of 53, by Intel486dx33
What ISA sound card do you think offers the best clarity and audio experience ?
Reply 13 of 53, by tpowell.ca
So far, from my investigations the ESS Audiodrive ES688 is ideal.
It is 100% Sound Blaster Pro compatible with what I've thrown at it, has a real Yamaha OPL3 synth, supports ADPCM samples and uses a sliding low pass filter (unlike the fixed freq on the SB Pro) so it sounds clearer.
Oh, and it has a line-out and speaker out.
Reply 14 of 53, by keropi
tpowell.ca wrote:
So far, from my investigations the ESS Audiodrive ES688 is ideal. It is 100% Sound Blaster Pro compatible with what I've thrown […]
hmmm I tested an 688 card with Duke Nukem 2 and after a while the sfx stop and the machine freezes - tested 2 different systems that work fine with the game using a CT1600. Am I missing something?
My card is this one:
I will also try your mixer first chance I get, thanks for sharing!
Reply 15 of 53, by bjwil1991
I also second that as well, or the ESS ES1688F since it can be switched between Sound Blaster DSP 2.01 and Sound Blaster Pro DSP 3.01 for the Sound Blaster emulation.
The card you have is almost similar to the one I have (I have the ES1688f).
I noticed DS0 doesn't have a jumper on there. Add a jumper to that and change the IRQ from 7 to 5 (IS1 = Open, IS0 = Close).
Reply 16 of 53, by tpowell.ca
Interesting. I'll have to try it.
Btw, my app will only be able to control the hardware filters on a TRUE Sound Blaster Pro.
Not a compatible card, not an SB16 or newer, nor a classic Sound Blaster 1.xx or 2.xx.
Reply 17 of 53, by keropi
the foto's angle tricks the eye, the card is configured for IRQ5 : IS1:open , IS0:closed
It was quite a bummer, at first all seem OK but after a while it seems the dsp goes out of sync or something and just crashes 😵
Reply 18 of 53, by bjwil1991
What about the DMA? It's set to none, or are my eyes deceiving me again? Try setting the DMA to 1 and it might work since the SFX uses the DMA.
Reply 19 of 53, by keropi
it's the weird angle, I've drawn some lines now - DMA is set to 1
I got confused too looking at the pic as well 🤣
