DOSBox and Roland RAP-10
First post, by McAbraxus
Ok, can't find any current data on this, so I'll ask here. I have a Roland RAP-10 card and is used to my DOS games sounded way better than the basic sound both originally in DOS, but also DOSBox. If I put in an ISA to PCIE or ISA to USB converter. Plug the RAP-10 in this. How would I go about using it in DOSBox?
Reply 1 of 2, by olddos25
You can't use it.
Just another user that likes old OSes and videogames, nothing interesting to see here...
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
Emaculation: https://www.emaculation.com/forum (as macplus)
Reply 2 of 2, by PgrAm
Not so fast,
Well, the RAP-10 is just a general midi board so as long as you get it working as a midi device in your OS then you can set it as an output for DOSbox's midi. My RAP-10 presents itself to DOS as an MPU401 UART so assuming you can find a modern driver for one of those you should be able to make it work, however it would seem the chances of that are slim.
A workaround would be to put the RAP-10 into an old PC and connect that to your new computer over a MIDI cable and use some midi forwarding software on the old PC to route that input to the input of RAP-10.
Currently working on new DOS game, Chuck Jones: Space Cop of the Future : https://chuckjonesdevblog.wordpress.com
WARNING: contains rocket powered El Caminos
