add an isa slot or card?
First post, by weldum
Hi,i was wondering if it could be possible to add an isa card or slot to a laptop.
'cause i have a 386sx based laptop that only has a speaker, and i have some soundcards (16bit isa) laying around that can use.
i would love to get or have a OPL2LPT or similar, but because of currency problems, buying it is not an option.
i've looking at the motherboard and it has a expansion-like connector, very similar to the expansion port of the commodore 64, but 'cause i know next to nothing about electronics i don't know what it is.
any help would be useful. thanks.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 6, by Errius
It's probably for a docking station. In those days laptops often had compatible docking stations with full length slots for expansion cards that could be used by the laptop when it was connected. You may want to see if your model ever had one.
"AI Requires Proof That You Are Human"
Reply 2 of 6, by weldum
it's hard to know, because the edge connector is not exposed, so i don't think it's an option.
also, i've not found a lot of information about this laptop, maybe i don't have searched really well, is an Acer AnyWare k386s, i've read that this model had other names depending on the market, mine is imported from the US i believe.
it has a 386SX-25, 4MB of RAM, an 80MB seagate HDD, floppy drive, 640x480 dstn maybe? grayscale screen and a Cirrus logic CL-GD5420 (acumos avga2 based?)
right now i'm working, but later i will take some pictures of the board and the laptop.
Reply 3 of 6, by stamasd
The only laptops I know of that have ISA slots in docking ports are as follows:
1. Thinkpad 350/360/750/755/760 series with either Dock I www.thinkwiki.org/wiki/ThinkPad_Dock_I_(3545) or Dock II www.thinkwiki.org/wiki/ThinkPad_Dock_II_(3546) (1 ISA and 2 ISA respectively)
2. Thinkpad 600/770 series with Selectadock I http://www.thinkwiki.org/wiki/SelectaDock_I (1 ISA), Selectadock II http://www.thinkwiki.org/wiki/SelectaDock_II or Selectadock III http://www.thinkwiki.org/wiki/SelectaDock_III (2 ISA).
There may be others, but these are the ones I know of.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 4 of 6, by weldum
forget about docking stations, this one doesn't have that, it has an edge connector in the motherboard and i was wondering if it may be possible to use an standard isa card there
Reply 5 of 6, by root42
Can you post some pictures of the edge connector?
And what are the currency problems your are talking about? An ISA sound card would have the added benefit of probably adding SoundBlaster compatibility, which the LPT devices won't have.
YouTube and Bonus
Reply 6 of 6, by weldum
i do have isa, Soundblaster-compatible cards, i cannot buy something like the opl2lpt or any other lpt sound card because i live in Argentina and the currency conversion is very unfavorable
