First post, by ux-3
After a search and some fiddling on my own, I found out why dosbox doesn't run on my analog TFT with fullfixed=false on a Geforce 6800. The modes are not supported at that refresh rate. Sure enough, there is a workaround, I have mapped the display to supported resolutuions, I also have a CRT sitting around.
However, on my vintage dos machine, I actually get an acceptable TFT picture once I increase the screen refresh rate beyond the 60 HZ threshold. My card had the dos software to do so. Now I have some small hope that incresing the refresh rate of the dosbox native output whould allow my TFT to catch the picture on my mainstay machine too.
I have tried the obvious, using coolbits2, to override the refresh rates of my Geforce. I checked with the CRT, but the actual output frequency did not change at all.
So: ** Is there a way to FORCE dosbox to run at a different refresh rate? **
I have a tool for a voodoo3, which allowed refresh rate manipulation, called VBEHZ. It needs Vesa 3.0 though, and didn't work in Dosbox.
I did find a relevant discussion in another section, but only moderators are allowed to post there, so I place my question here. Thanks for any help!
ux-3
