First post, by AtTheGates
I'm having issues running Warcraft III on my Voodoo II. It says it can't detect Directx 8.1, even though 9.0c is installed. I know an 8MB ATI Rage card can run this, so any ideas?
Reply 1 of 9, by F2bnp
What is the primary video card that you use on this system?
Reply 2 of 9, by appiah4
I believe Warcraft 3 requires not only DirectX 8.1 but a card capable of DirectX 8.1, so the Voodoo 2 can't play it in Direct3D mode.
Drop the releveant Glide ovl file into the game directory and run it in Opengl mode. Use FastVoodoo 4.6 drivers for better compatibility.
Reply 3 of 9, by AtTheGates
A purely 2D card to avoid any clashes with the Voodoo II. it's an S3 Trio 64 PCI.
Reply 4 of 9, by AtTheGates
The game will definitely run on DX6 cards such as an ATI Rage XL, so it should run on a Voodoo II!!
Good point about OpenGL. I totally forgot it supported that.
Reply 5 of 9, by F2bnp
Warcraft III might be detecting the Trio64 only and essentially complaining that you don't have a D3D accelerator. I know it is fun to run newer games on hardware that should have no business attempting to play them, but perhaps you should give this one a pass, it'll run like a turd on that V2 anyway.
Reply 6 of 9, by AtTheGates
If a Rage XL can run it, I don't see why a Voodoo II can't!! 😜
Reply 7 of 9, by AtTheGates
Ok, figured it out. Placing the MesaFX OpenGL32.DLL file into the game folder and running WIII in OpenGL mode worked. The performance isn't the greatest (though about playable at a stretch), but it's all rendered correctly. Running at 640x480 or 800x600 doesn't seem to affect performance either.
With 2 12MB Voodoo IIs in SLI I'd imagine it would be totally playable at 800x600 with medium textures. My Voodoo II with 8MB produces glitches if I set the texture quality anything above low!" xD
Reply 8 of 9, by leileilol
appiah4 wrote:
I believe Warcraft 3 requires not only DirectX 8.1 but a card capable of DirectX 8.1, so the Voodoo 2 can't play it in Direct3D mode..
It's just the API in this case (and not the caps, as many assume DX81 required = DX81 class hardware required). I know a Voodoo3 can work and look fine, especially as Warcraft3's technical art direction hasn't really changed from its 1998 spec.
Reply 9 of 9, by AtTheGates
The graphics aren't much of a step up over Dungeon Keeper II.
