First post, by AtTheGates
- Newbie
I'm having issues running Warcraft III on my Voodoo II. It says it can't detect Directx 8.1, even though 9.0c is installed. I know an 8MB ATI Rage card can run this, so any ideas?
What is the primary video card that you use on this system?
wrote:I'm having issues running Warcraft III on my Voodoo II. It says it can't detect Directx 8.1, even though 9.0c is installed. I know an 8MB ATI Rage card can run this, so any ideas?
I believe Warcraft 3 requires not only DirectX 8.1 but a card capable of DirectX 8.1, so the Voodoo 2 can't play it in Direct3D mode.
Drop the releveant Glide ovl file into the game directory and run it in Opengl mode. Use FastVoodoo 4.6 drivers for better compatibility.
wrote:What is the primary video card that you use on this system?
A purely 2D card to avoid any clashes with the Voodoo II. it's an S3 Trio 64 PCI.
wrote:wrote:I'm having issues running Warcraft III on my Voodoo II. It says it can't detect Directx 8.1, even though 9.0c is installed. I know an 8MB ATI Rage card can run this, so any ideas?
The game will definitely run on DX6 cards such as an ATI Rage XL, so it should run on a Voodoo II!!
Good point about OpenGL. I totally forgot it supported that.
Warcraft III might be detecting the Trio64 only and essentially complaining that you don't have a D3D accelerator. I know it is fun to run newer games on hardware that should have no business attempting to play them, but perhaps you should give this one a pass, it'll run like a turd on that V2 anyway.
wrote:Warcraft III might be detecting the Trio64 only and essentially complaining that you don't have a D3D accelerator. I know it is fun to run newer games on hardware that should have no business attempting to play them, but perhaps you should give this one a pass, it'll run like a turd on that V2 anyway.
If a Rage XL can run it, I don't see why a Voodoo II can't!! 😜
Ok, figured it out. Placing the MesaFX OpenGL32.DLL file into the game folder and running WIII in OpenGL mode worked. The performance isn't the greatest (though about playable at a stretch), but it's all rendered correctly. Running at 640x480 or 800x600 doesn't seem to affect performance either.
With 2 12MB Voodoo IIs in SLI I'd imagine it would be totally playable at 800x600 with medium textures. My Voodoo II with 8MB produces glitches if I set the texture quality anything above low!" xD
wrote:I believe Warcraft 3 requires not only DirectX 8.1 but a card capable of DirectX 8.1, so the Voodoo 2 can't play it in Direct3D mode..
It's just the API in this case (and not the caps, as many assume DX81 required = DX81 class hardware required). I know a Voodoo3 can work and look fine, especially as Warcraft3's technical art direction hasn't really changed from its 1998 spec.
wrote:wrote:I believe Warcraft 3 requires not only DirectX 8.1 but a card capable of DirectX 8.1, so the Voodoo 2 can't play it in Direct3D mode..
The graphics aren't much of a step up over Dungeon Keeper II.
