First post, by Pabloz
i was given this board for 3 dollars including riser and heatsink
but it uses some strange power supply that i don't have
near the cpu there is a 6 pin connector, and one of the cables is grey while the others are brown and black, so im not sure what voltage the grey cable needs to have. Any idea?
thanks to an ebay auction i was able to find some pictures on what the machine looked like, This is not my pc:
this is the board i got, the one i have:
i was able to find online the pinouts:
https://allpinouts.org/pinouts/connectors/pow … -supply-13-pin/
Non-standard ATX MB power connector with additional 6-pin Molex for 3.3V
Single-in-line Molex-like 13-hole connector with one hole empty. Looking on the metal latches side of the connector, wires UP, “1st” pin is on the LEFT. PSU’S Additional 6 pin Molex 3.3V connector pinout is BLACK WIRES=GND, BROWN WIRES=+3.3V
Pin Name Color Description
1 -5V purple -5V 0.2A
2 -12V green -12V 0.5A
3 +5V red +5V
4 +5V red +5V
5 +5V red +5V
6 +5V_STBY orange +5V Standby, seems not more than 50mA
7 +12V yellow +12V
8 GND black
9 GND black
10 GND black
11 PWR_ON white Power ON from motherboard, ON=LOW (short it to GND for power on)
12 empty pin removed, closed with a plastic plug
13 PG blue Power Good to motherboard, PG=Hi
