First post, by Xenphor
I bought a leadtek geforce 4 ti 4800se and it produces a blurry image at resolutions over 800x600. This happens in both windows 98 and linux, even if I use a dvi-i to vga adapter. Using digital output over dvi seems to be fine at least. Is this a sign that the card is going to die soon or is there a way to fix it? There doesn't seem to be anything wrong with the board itself like leaking capacitors.
I have an asus geforce 4 ti 4800se that I've used with the same system that doesn't have the issue.
Reply 1 of 6, by The Serpent Rider
Cable.
Reply 2 of 6, by appiah4
Shitty RAMDAC was somerhing very common in dx8 and earlier nvidia cards.
Reply 3 of 6, by Xenphor
The Serpent Rider wrote:
Cable.
You mean there's something wrong with the cable? It's the same vga cable I use with the other geforce 4 and it's fine above 800x600.
But what would dx8 have to do with it? It's fuzzy and blurry just sitting at the desktop, even at 1024x768. I don't seem to recall that being a problem even with an nvidia tnt I had.
Reply 4 of 6, by leileilol
It's more of a broad way of saying "everything before the GeforceFX"
Reply 5 of 6, by darry
If you need to have VGA output, an active DVI to VGA converter (from the likes of Gefen , Atlona or Extron) could be an option . That being said, the card is probably fine . Like the previous posters said, VGA output quality tended to be iffy on cards of the era, especially Nvidia based ones .
Reply 6 of 6, by Xenphor
Using dvi-d seems to mess with the refresh rate of games on my display so I don't think using an active converter would help much if it's still using the digital signal.
So if I want to increase the longevity of the asus 4800se I have, what could I do? Is cooling an issue on these cards? The leadtek version has a fairly massive heatsink on it that covers a large amount of the card as well as the back; however, the asus model only has a small heatsink centered on the gpu. Would it be worth while to buy some smaller heatsinks to put on other parts of the card that are not covered?
I would try to monitor the card's temperature in Windows but I don't think it has any sensors on it.
