Reply 80 of 202, by Roman555
wrote:wrote:Yes, it would be better to remove caps from the board temporarily. And with a bottom preheater you could decrease temperature o […]
wrote:I now noticed that I burned some electrolytic capacitors with the hot air so they leaked some black thing.
And with a bottom preheater you could decrease temperature of hot air.
Although the pads look good (not overheated, IMHO)My suggestion for SMD chips and capacitors would be to use an SMD soldering/desoldering iron.
I agree there's special mini-wave tips to ease soldering of PQFP chips.
But it's pretty tiresome to desolder pin by pin a PQFP-160 chip with an ordinary soldering iron. With hot air soldering/desoldering is much faster.
Of course it can be done if hot air isn't in hand.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
