First post, by Xenphor
I bought a leadtek geforce 4 ti 4800se and it produces a blurry image at resolutions over 800x600. This happens in both windows 98 and linux, even if I use a dvi-i to vga adapter. Using digital output over dvi seems to be fine at least. Is this a sign that the card is going to die soon or is there a way to fix it? There doesn't seem to be anything wrong with the board itself like leaking capacitors.
I have an asus geforce 4 ti 4800se that I've used with the same system that doesn't have the issue.
