First post, by retro games 100
Can anyone tell me a little bit about this card please? (The Elsa Winner 1000 Pro VLB video / graphics card.) It has 2MB, so does that mean that its memory (or is that data?) path is 64-bit, or is that not necessarily the case?
2) There's an S3 branded chip in it that says SDAC. Is that its RAMDac, and if so, does it have a certain "bit depth"
3) There is a little blue "switch box" on the card, with little white switches. One setting written on the PCB says: Open = 1st board BIOS. What does that mean?
4) There is a 25 pin connector on it. Is that a feature connector, and if so, what's it for exactly?
5) The card uses the S3 Vision868 86C868-P chipset. Is this good for both DOS and Windows?
Thanks very much for any comments!
Reply 1 of 8, by kixs
1. yes it does
2. yes. No idea about bit depth
3. you can have more of these cards installed. If you select 1st board BIOS, that would be the main card
4. MPEG addon daughterboard
5. yes and yes
No problem 😉
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 2 of 8, by retro games 100
Thanks a lot!
So, just going back to question 1 please, regarding the 64-bit issue, would this 2MB card have a 64-bit wide data bus, or is it a 64-bit wide memory bus? Or both??
Thank you.
Reply 3 of 8, by Anonymous Coward
S3 864 should be 64-bit internally, and should also have a 64-bit path to memory unless only 1MB is installed.
Reply 4 of 8, by fitzpatr
The VESA Feature Connector could also be used for a TV Tuner or other capture card. In this case, the Vision868 has an MPEG decoder built-in, which would probably negate the need for a separate one.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 5 of 8, by root42
Not quite full MPEG. More like scaling and Yuv to RGB conversion.
YouTube and Bonus
Reply 6 of 8, by fitzpatr
Thank you for the correction. Unfortunately, I've only got 864 and 964 cards, so I haven't been able to play with that feature!
486 Build
Reply 7 of 8, by retro games 100
Thanks a lot for the info, people! btw, what are your experiences with the S3 864 chipset? For instance, is it a "good all rounder"? Thanks.
