First post, by dionb
Not too sure about 3.x specifically, but as for DOS you have a few choices. Question is whether you have a PC/PCI connector on your motherboard.
If so, you have a wide range of choices, with the Yamaha XG (744-based) cards probably being the best bet.
If not (more likely) you need a card that does some trickery in a TSR driver. In that case, look for things like the Aureal Vortex, Ensoniq ES137x (SB PCI 16/64/128) or ESS Solo-1 chipsets.
Reply 1 of 4, by canthearu
ESS Solo-1 is a good option.
I had that running for a bit on windows 3.1
Reply 2 of 4, by canthearu
Sb live doesn't have drivers for windows 3.1
Reply 3 of 4, by leileilol
I think the original Ensoniq AudioPCI 1370 have W3x drivers available, though not the 1371 and later (i.e. SBPCI128)
Reply 4 of 4, by dionb
mr tibs wrote:
PC/PCI connector ? You mean SB link?
"SB-Link" is Creative's name for it. As Soundblaster is a trademark, the rest of the industry called it PC/PCI.
Given that Creative themselves stopped using their SB-Link almost as soon as the introduced it, I'm using the far commoner name used by vendors who did keep implementing it for at least a short period.
For more info:
https://ilovepa.ws/2017/06/27/motherboards-with-pc-pci/
