First post, by Half-Saint
Hey guys,
I'm trying to solve an issue here. I'm testing an SC-55 that works fine when I play the built-in tunes but doesn't pick up the music from Doom. That's the only game I tried so far. The result is the same with or without SoftMPU.
Sound card is a Sound Blaster 16 CT2290 (IRQ5/240H/DMA1) and MIDI is at 330H. I'm connecting the cable to MIDI IN on SC-55 side.
What am I doing wrong?
Cheers
EDIT: for anyone that might run into the same issue.. you have to reverse the cables! The one that is labeled OUT goes to IN on SC-55 side 😀
Reply 1 of 4, by keropi
seems like a cable issue? soundcard midi-OUT goes to SC-55 IN like you do but are you sure the cable is correctly wired and in ood shape and the adapter good?
Reply 2 of 4, by Half-Saint
I reversed the cables. I plugged the IN cable into the IN connector 😀
Reply 4 of 4, by Half-Saint
Yeah 😀
