Reply 20 of 28, by ruthan
 - Oldbie
It would be worth mentioning that this chip includes a real OPL3. Furthermore, this card (as the only one I know) even on the most modern chipsets * without * native PCI bus (eg Intel Z97) under Windows 98 Sound in DOS applications play.
under Windows 98 Sound in DOS Doest it means that it working in Pure Dos (Windows 98 DOS 7 too) too? Because i have quite few cards for example Audigy and SB Live! which are working with every modern board - which is able to boot Windows 98 (for example Z97), but its not working in Pure DOS. im not sure for now about Windows 98 Dos window mode.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
