First post, by Xenphor
System:
Pentium e5800
ASRock 775I65G R3.0
geforce 4 4800se 45.23
yamaha ymf 744 5.12.01.2228 WDM
512mb ram
I've had issues getting dos games running in Windows with this system. I realize it's not the ideal configuration using a WDM driver, but I don't have an optical drive currently and would prefer using daemon tools. This exact setup has worked on a socket 939 motherboard with VIA chipset (asus a8v-x), so I'm wondering if there is anything I can adjust to help with running dos games in Windows on the 775 board.
One main game I want to play is need for speed 1 se. This installed and played mostly okay on my socket 939 board, although some sound effects were glitchy. However, on my 775 board the game does not install at all. In fact, the only dos game that appears to run so far is doom with sound effects and music.
What things would typically prevent dos games from installing/running in Windows on a more modern setup, assuming there isn't an inherent compatibility issue?
