Atom Ant wrote:So, I spent 1,5 hours with it and it is working finally :) The best thing, i insereted one of my big old floppy disc into the dr […]
So, I spent 1,5 hours with it and it is working finally 😀 The best thing, i insereted one of my big old floppy disc into the drive and it could read! After 21years... And the disc contained a game, that I just start to remember..., called Wolfpack,
Cannot wait to read the rest of my big floppy discs...
However the drives are only working if I put the small floppy drive to the 3.connector and the big floppy to the second. And it is not the most convinient way, because it does not give enough space to fit the drives into their space. I would need cable with longer distance between the connectors or some extension.
If I could use the 4th connector for the big floppy and the 1st connector for the small floppy Everything would fit comfortable. But Unfortunatelly I do not see in bios the swap floppy option.
Matth79
What is that terminator option?
Ah, cool! So, what was it? Just a wrongly connected cable?
Yeah, also been astounded by those 5.25" floppies resilience. Repaired my old C64 which had a broken serial interface a while ago (two decoupling diodes were blown), and all but one of those 30-35 years old floppies I tried afterwards worked just fine 😀
Well, the first thing I'd try would be to connect and pull that cable a few times to ensure it makes contact, just in case the connectors has oxidized/gotten dirty through the years. If that won't work, it might be an idea to have a closer look at those jumpers, might be that you have to do some configuration after all. A sharp closeup pic of the jumper header, where any PCB markings are readable, would probably be helpful.
Wiki explains electrical termination far better than I ever could in a non-native language. If there's a termination jumper, you'd have it closed if the drive in question was the last in the chain (read: as A drive on the 3rd or 4th connector), to terminate the signal cable.
The more modern 3.5" drives terminates automatically. Never seen one you have to terminate manually at least.
