386SX wrote:What about a Q6600 solution with a DDR3 motherboard? Would it be "fast" enough?
I have both systems: a Phenom x6 1090T @ 4.07GHz, and a Q6700 (65nm) @ 4.00GHz on a DDR3 motherboard. I prefer the Phenom. It is slightly faster than the Q6700 in single-threaded applications (possibly due to the 70 extra MHz), and blows it away in well-threaded apps.
But IMO, applications that can make use of 6 cores should be run on a much faster system. So if, for some bizarre reason, you're restricting yourself to pre-Nehalem hardware, the 45nm C2Q becomes the ideal choice. Single-threaded performance is slightly higher than that of Phenom II and 65nm Core 2. They easily hit 4GHz and run cooler to boot. They also feature the SSE4.1 instruction set--something that both the 65nm Core 2 and Phenom II lack. More programs are starting to require SSE4.1.
"A little sign-in here, a touch of WiFi there..."
