First post, by Strahssis
- Member
Hey guys,
I recently built a retro gaming PC targeting the late 90s and early 2000s era. I used the following build for my PC:
CPU: Intel Celeron SL68C 1.70GHz/128KB/400MHz Socket 478
RAM: 256MB Samsung DDR1-266MHz PC2100U
256MB IBM DDR1-266MHz PC2100U
HDD: Transcend Standard 16GB CF-Card 133x in CF2IDE Adapter
Drives: CD-RW + DVD + 1,44MB Floppy Drive
PSU: Inter-Tech SL500A ATX 500W
Motherboard: GIGABYTE GA-8SIML mATX Socket 478
GPU: AOpen MX4000-V64 NVIDIA GeForce 4 MX4000 64MB
Sound Card: CMI8738 C3DX HSP56 5.1
Network Card: Generic 56K Modem Card
CPU-Cooler: AVC 117160 Socket 478
Case: Packard Bell iMedia 3733VL mATX
After I built it I installed Windows 98SE and it installed just fine. However, I'm running into some issues when installing the drivers. There are three devices that are not yet installed after a clean install:
NVIDIA GeForce MX4000
C-Media CMI8738
Realtek RTL8139A (Onboard)
I honestly expected there to be more drivers left to install, but only these three apparently. Even the USB-ports work in the clean install.
When installing the NVIDIA GeForce 4 MX4000 I used Forceware version 81.98. It appears to install just fine, but when I try to reboot I get a protection error and Windows tells me to reboot my machine. I'm only able to access safe mode and editing the MaxPhysPage-line doesn't make any difference. I also tried this doing this proces with only 256MB of RAM installed, but also then, I get the same error. I also tried using a different Forceware version; version 56.64. Again, it appears to install just fine. When rebooting however, I don't get a protection error, but the PC freezes at the Windows 98 boot screen and the PC makes an endless beep. This time I couldn't access safe mode either, because it also froze and beeped endlessly.
When installing the C-Media CMI8738 and the Realtek RTL8139A it also appears to install just fine. However Windows fails to actually use the devices after reboot. Windows will try to boot, but it will try and fail to boot two times. Then it boots up and turns of the devices I just installed. The device manager properties claims that Windows was unable to boot using the devices, so it stopped trying to use them.
I also tried using Windows ME instead of Windows 98SE out of despair, but I get the same results there. I could try Windows 2000 or Windows XP, but I honestly really don't want to do that as that way I will lose the ability to use my sound card in DOS-games. Does anyone of you guys know how to fix this issue? I'm looking forward to hearing from you soon,
Sincerely,
Miko, Strahssis
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Sound Blaster CT2800, 32MB RAM
Satellite 220CS: Pentium 133, SVGA DSTN, Sound Blaster Pro, 64MB RAM
Contura 420CX: 486DX4 75, VGA TFT, Roland Serial MIDI, 16MB RAM
