First post, by Eric Wright
I am running the most recent ykhwong 0.63 DOSBox version, but although the a: appears to be mounted correctly and I can list files that are on the drive using "type", I seem to be unable to copy files from the a: to the c: using "copy". I always get a "File not found" error - any ideas ?
I have to say that this version of the program has been a lifesaver for me as I have an old DOS application that needed serial port and printer port access to function and our last DOS machine fried last month. We are now running it on a modern machine under XP.
Regards Eric Wright
Reply 1 of 5, by eL_PuSHeR
Is this problem also happening with official 0.63?
Could you write down the exact commands you used?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 5, by ykhwong
Thanks for your report. (move command will properly work instead.)
The bug will be fixed on next release.
Reply 3 of 5, by Eric Wright
The commands that I was trying were :
copy a: filename.dat // Executed from c:\cal
copy a:filename.dat c:\cal
copy a:filename.dat c:\cal\filename.dat
copy a:*.* c:\cal
None of the above worked.
However I have just tried ykhwond's suggestion of using the move command and that works fine.
Regards Eric Wright
Reply 4 of 5, by DosFreak
Hmmm, sometimes when I copy files I:
1. Go to the directory where I want the files.
CD \games
2. Copy the files to the directory
Copy A:\*.*
This would copy the files from A:\ to \games as long as your in \games.
Make your games work offline
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
I think it's just caused by some modification by ykhwong.
as he modifies quite a few shellcommands.
(and judging from his reaction "bug fixed next build")
Water flows down the stream
