Baoran wrote:I might be wrong but as I understand all pentium III cpus are multiplier locked, so if multiplier of your cpu is 5.5x, it would be 550Mhz at 100Mhz FSB and 733Mhz at FSB of 133Mhz and that would make it a 733Mhz cpu.
If I am wrong, I am sure someone corrects me.
I'm not positive about the lock (but pretty sure you're right) but yes there are 100mhz and 133mhz bus flavors. As said above, there is a CPUID instruction on processors going all the way back to the original pentium that cpu-z is "calling" which returns everything about the CPU including it's stepping, model, type, etc. If his motherboard is running at 100 bus a 1ghz cpu would run at 733mhz as you say(unless there is something up with the board or it doesn't support his model? or its running at 66mhz bus?? ). I suspect we're also talking about a P3 733 here though.
I do think CPU-Z shows the current operating speed but the specification up top should show more exact information. Is there any kind of Model showing in cpu-z you can go ahead and paste in google to check? Otherwise, I would pull the heatsink and check, it wouldn't hurt to put some fresh thermal compound on it anyway in the process of verifying seller didn't lie to you.
Sup. I like computers. Are you a computer?
