Korg NS5R Question
First post, by Salient
Hi all,
I recently acquired (once again) a Korg NS5R and I want to install a daughterboard in it.
The question now is how can I, when playing back a MIDI file, choose to play it through the daughterboard only? I beleve the board utilizes channel 33 - 48 but I want to use these channels as 1 - 16 in that case.
I hope somebody knows the answer. 😀
Reply 1 of 3, by SuperDeadite
Go to the midi port matrix screen. You can select which port each channel goes to. Port "C" is the daughter board.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 2 of 3, by Salient
Thanks! I'm going to try it shortly!
Edit:
It works like a charm! Thanks again!
I saved this in a profile (within the multimode menu) so I can quite easily choose between native NS5R and SCB-7 now. 😀
Reply 3 of 3, by moturimi1
Salient wrote:
Renewed MIDI comparison website: << wavetable >>
Thank you for updating your homepage. Great to see some new recordings.
Maybe you want to advertise your new homepage in a different thread.
