First post, by user33331
- Member
Hello
I have broken so many fragile old plastic threads: screw diameter sizes 2,3,4(mm).
Threads either cracked or weared out due to multiple openings causing screws to spin.
So I must be doing something wrong.
Do you use those small torque hand screwdrivers(unmotorized) ?
Can you recommend a certain brand ?
What torque Nm do you use for 2,3 and 4mm diameter screws ?
- Do you put some specific rejuvenating grease or oil to old plastic thread holes first ?
What to do when threads crack ?
- Any plastic thread hole healers ? To seal the cracks and rethicken the thread ?
- Quick\super glues as Loctite just cracks open again due to pressure.(So no to quick/super glues)
- Teflon=plumber's tape sometimes helps if the hole is large.
