First post, by norolim
I have an 2D VGA PCI card, that I wont to test. Unfortunately, my Socket 1 board doesn't have any PCI slots. The only thing I could test it on is my Windows 98 machine, that runs on a board manufactured between 2001 and 2003. Will it work? Is there anything I should know before I try? Are there any BIOS settings I need to configure?
Reply 1 of 8, by emosun
what card is it? I didn't know a 2d exclusive card existed on pci
Reply 2 of 8, by SW-SSG
Should work. Most boards by default will check the PCI slots before the AGP for graphics cards.
There are... literally hundreds? S3 Trio64, Cirrus CL-GD54xx, Trident TGUI9xxx, etc. Maybe you're thinking about something else.
Reply 3 of 8, by emosun
3d like with shutter glasses or 3d as in polygons on a screen? I guess if it's not compatible with glasses or googles then i guess every card would be 2D. I forgot that 2d could just mean the final image. 🤣
Reply 4 of 8, by norolim
It's a Tseng ET4000. Tested it. Not displaying anything 🙁
EDIT:
OK, the only problem I can think of, apart form the card being dead, is a PCI version compatibility issue. PCI v2.2 introduced 3.3V slots, which would not power a 5V card. However, the Internet says, the key position in the 3.3V and 5V slots was different, so a 3.3V card would not fit in a 3.3V only slot. Can someone confirm it was a standard and there was no physical way to insert a 5V card in a 3.3V slot?
Reply 5 of 8, by Ozzuneoj
EDIT:
There may be some other compatibility issue, but it is unlikely to be the voltage since even on the latest boards that had PCI slots they were usually keyed for 5v PCI compatibility. I believe the exception would be later 64bit PCI cards for workstations and servers. This is an interesting page about PCI compatibility:
http://www.ni.com/product-documentation/54456/en/
Likewise, there are very few PCI cards that are keyed for only 3.3v use (rather than universal cards with both keys) outside of workstation and server parts.
Reply 6 of 8, by dondiego
The card should work, you don't need to worry about that shit. I'm a computer technician so i should know what i'm talking about. 😀
Just take the agp card out and put the pci one in. If it doesn't work most likely it's not properly inserted in the slot, you need to insert it firmly, some force is required but don't apply too much. With some cases it's a bit tricky, you could try inserting the farther side from the connector first.
The card could also be bad of course.
LZDoom, ZDoom32, ZDoom LE
RUDE (Doom)
Romero's Heresy II (Heretic)
Reply 7 of 8, by ODwilly
Look for a bios option for "Initial display" or something along those lines. Sometimes it will be set to AGP and just ignore pci cards. Also with a card that old it may not be playing well if you are using a modernish LCD.
In that case I have noticed the LCD will light up and try to detect the vga signal but either just stay black or say "out of range".
Reply 8 of 8, by norolim
Thanks for all the replies. Unfortunately, the card is bad.
