Couple of years ago i wanted to test the whole range of 3dfx cards and voodoo1 and rush did not work on my testbed: Asus Tusl2-c (intel 815) with 1400 Tualatin P3.
Even after setting the fsb to 66mhz to get 700mhz cpu none of these cards worked. I tested 5 voodoo1 cards and 2 Rush cards, all of them worked fine on a p200 mmx. So yes, they can be very speed sensitive or even platform sensitive?
btw most installed fine but just turned to black screen when used. Voodoo2 and up had no issues.
