First post, by Compo Simmonite
Hey, new member and straight in with a question if i may.
I was given a Compaq deskpro 2000 as well as the original ps2 keyboard and mouse the other day, that had spent its life in a cupboard as a barcode reader for clock cards and so physically is in very good condition. It was running win 2000, i have changed this to 98se and managed to keep the on disk bios intact.
The 2 gig disk though sounds like it is on its last legs, and i have tried fitting a larger disk to no avail - just throws up an error even with the 8 gig limit jumper fitted.
Also tried a 2 gig cf card in an adapter but also gives errors as you can only choose master or slave on the adapter, the hdd fitted is jumpered for cable select.
Any ideas please?
Will post up some pictures in due course.
Thanks!
