First post, by Atom Ant
I have two wonderful Pentium II Overdrive 333MHz processors, but i am unsure what Socket 8 motherboard I need. I've tried them already with a Megastar TD6NF motherboard with Intel Natoma 440FX chipset. it is like in new condition and fires up right with a Pentium Pro 200MHz CPU. However when I switch the CPU for the Overdrive, the screen stays dark and it not even make a beep or anything, just the fans spinning up. Would I need to do any more adjustments, than just change the CPU?
If this motherboard won't be compatible, what other would you reccommend? I personally would like a single CPU solution, I do not plan both of the CPUs running...
Some pics of the motherboard and about the CPUs;
My high end of '96 gaming machine;
Intel PR440FX - Pentium Pro 200MHz 512K, Matrox Millenium I 4MB, Creative 3D Blaster Voodoo II 12MB SLI, 128MB EDO RAM, Creative Sound Blaster AWE64 Gold, 4x Creative CD reader, Windows 95...
