OS X Port-DPMI Error
First post, by OSXer
I've been searching through the forums and have found users that have had similar problems but no definitive answers. When I try loading most of the DOS .exe I am using I get the error saying the DPMI is missing and need to get csdpmi*b.zip. Welll I have the file but I am having problems trying to figure out how to get it working with the port. The only files that I can visibly see that were in the port was DosBox, the actual app, and a few notes on the porting and use of the system.
If any users know how to fix this please enlighten me. And note, I am just starting to learn DOS so simplifying everything in explaination would be greatly appreciated.
Reply 1 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
you need the dos version of csdpdmi. as you run it in a dos emulator.
Water flows down the stream
Reply 3 of 8, by OSXer
Ok thanks for the help. Only last question is where exactly do I place the stuff and how do I go about doing it?
Reply 4 of 8, by HunterZ
Put it in the same directory/folder as the game's .exe file and the game will use it automatically.
Really it should have been included with the game unless they were expecting you to run in a DOS window in Windows instead of pure DOS.
Reply 5 of 8, by OSXer
Ok. Thanks for the help, it cleared up that issue! However now I got DosBox full out quitting, I believe from an error. I think it is most likely the game. So you know I am trying to run Zelda Classic (DOS) in DosBox, but it may not be compatiable...
Reply 6 of 8, by HunterZ
For help on that we will need the info asked for in the help requesting guidelines here on the forum...
Reply 7 of 8, by OSXer
Ok, I am running an iMac G4 with Superdrive. The specs from the profiler are:
*800 MhZ PowerPC G4
*768 MB RAM (SDRAM)
*100 MhZ Bus Speed
*NVIDA GeForce2 MX with VRAM of 32 Mb
*Built In Sound Card by Texas Instruments TAS3001C (44.1 Khz) (1 input, 3 output)
*Mac OS X 10.4.3
*Zelda Classic (from www.zeldaclassic.com) 2.10 DOS version
*When trying to launch zelda.exe, the program automatically quits out without warning. The same thing happens with zquest.exe, the quest editor.
*Reproducibility: Always
*Here is the dosbox.conf file:
[sdl] # fullscreen -- Start dosbox directly in fullscreen. # fulldouble -- Use double buffering in fullscreen. # fullfixed -- Do […]
[sdl]
# fullfixed -- Don't resize the screen when in fullscreen.
# fullresolution -- What resolution to use for fullscreen, use together with fullfixed.
# output -- What to use for output: surface,overlay.
# hwscale -- Extra scaling of window if the output device supports hardware scaling.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lower,normal,higher,highest.
# Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
fullscreen=false
fulldouble=false
fullfixed=false
fullresolution=1024x768
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory dosbox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=16
[render]
# frameskip -- How many frames dosbox skips before drawing one.
# aspect -- Do aspect correction.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,advmame2x,advmame3x,advinterp2x,interp2x,tv2x.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# core -- CPU Core used in emulation: simple,normal,full.
# cycles -- Amount of instructions dosbox tries to emulate each millisecond.
# Setting this higher than your machine can handle is bad!
# cycleup -- Amount of cycles to increase/decrease with keycombo.
# cycledown Setting it lower than 100 will be a percentage.
core=normal
cycles=3000
cycleup=500
cycledown=20
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
# mpu401 -- Enable MPU-401 Emulation.
# intelligent -- Operate in Intelligent mode.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,none.
# config -- Special configuration options for the device.
mpu401=true
intelligent=true
device=default
config=
[sblaster]
# type -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# base,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the dosbox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3.
# On auto the mode is determined by sblaster type.
# oplrate -- Sample rate of OPL music emulation.
type=sb16
base=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# base,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# rate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=true
rate=22050
base=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# Tandysound emulation is present if machine is set to tandy.
# disney -- Enable Disney Sound Source emulation.
pcspeaker=true
pcrate=22050
tandyrate=22050
disney=true
[bios]
# Nothing to setup yet!
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
xms=true
ems=true
[modem]
# modem -- Enable virtual modem emulation.
# comport -- COM Port modem is connected to.
# listenport -- TCP Port the modem listens on for incoming connections.
modem=false
comport=2
listenport=23
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
*DosBox v0.63 Mac OS X Port
I hope this is what you needed, if there is anyother information I need to provide, please tell me and I will get it to you ASAP. Thank you again for your wonderful help!
Reply 8 of 8, by HunterZ
Try:
- core=full and core=dynamic
- memsize=63
- xms=true, ems=false
- xms=false, ems=true
- xms=fasle, ems=false
Also, is there a setup/install/config program that comes with the game? Make sure to run it inside of DOSBox before trying to run the game.
