First post, by SETBLASTER
- Member
this is like voodoo magic for me, not the 3dfx voodoo magic
If i put many old cdrom drives horizontally, either the tray wont open on some models, or if he tray does open...the drive never reads the disk.
If i put the same drives, with the face facing up some degrees...the drives all of them start to read the disk
the tray not opening is because of the O-ring that needs to be replaced. but we can get along with it inserting a paper clip.. that is fine, but how come the drive never reads the disk if the drive is set on a flat surface ...i have no clue
