Kings Quest 6 Collection Series
First post, by dudemang
I just can't seem to get this game to run on XP. I tried installing it on windows and running it in windows. Screen goes black as if switchign into the game then goes directly back to desktop. I've tried using DOSbox. And it will just tell me to "Please insert cd 2 and press any key" and i do but it will keep repeating that message. Then i tried the DOSONLY install of it...and still, asks for the CD. Any help at all would be great. Thanks.
Reply 1 of 25, by HunterZ
I can't remember the key (it's in the DOSBox readme), but there is a key (ctrl+fsomething) for refreshing/swapping disks. You need to use this hotkey to tell DOSBox to re-read the CD so that it will see that you have changed it.
Reply 2 of 25, by dudemang
thanks for the reply but i couldn't find anything about a hotkey that makes the cd reread it...anything else?
Reply 3 of 25, by HunterZ
It's in there, I promise - it's just a bit hard to find. Also, the description isn't CD specific -- it's more like "flush disk cache" or "swap floppy disks" or something like that. Look around the readme for the description of what the Ctrl+F1 through Ctrl+F12 keys do and you should be able to find it.
Reply 4 of 25, by dudemang
ok well i found out it's ctrl+F4....however it doesn't do anything..at all...basically it just keeps saying "Please Insert Disc 2. Press Any Key To Continue". and i do...and it will say it again, and again, and again, etc. any other suggestions?
Reply 7 of 25, by dudemang
yes...2nd cd in...and drive mounted...mount e "e:\" -t cdrom -usecd 1 -ioctl
tried all those....anything else?
Reply 8 of 25, by Kenneth
As far as I know you should be able to install the games through DOS in Windows. If not open your CD folder and copy all the contents to seperate folders in your hard drive. And for games 5-7 add this to your RESOURCE.CFG file.
audio = RESOURCE.AUD
cd = no
My Kings Quest 5 CD does not have a RESROUCE.AUD File, it is called AUDIO.001
Reply 10 of 25, by dudemang
*hmph* i'm giving up on dosbox..it's just not working. would it be a bad idea to load an os on the side just for shits and giggles? like 3.1 or 95? lemme know thanks
Reply 11 of 25, by Reckless
You think that 'loading an os on the side' is gonna be easier than DOSBox ??? Tried a CVS version of DOSBox ?
Reply 12 of 25, by Kenneth
Good thing the Kings Quest Compilation will be XP Compatible.
Reply 13 of 25, by HunterZ
King's Quest Compilation? Is that some new collection being released by Vivendi? Are they going to bundle some DOS emulator or new AGI/SCI interpreter to make them run in XP and above without problems?
Reply 14 of 25, by DosFreak
Yeah, I've heard about it but not much info expect that they are re-releasing the games.
Amazon Link: http://www.amazon.com/exec/obidos/tg/detail/- … ogames&n=507846
Lots of speculation but no real facts. I just love how people always assume that it'll have 100% compatibility with XP and be BETTER THAN EVAR! heh. It's NEW! IT MUST BE GOOD!
Ahh, the ignorance of youth. 😀
If it's anything like any previous re-releases:
1. It'll have no fixes....at all. (Yet the requirements will list it as "XP Compatible")
2. It'll be bundled in a new installshield installer. Oh yeppe! A DOS game with an installshield installer!
3. It'll have fixes alright.....fixes that break the game.
4 It'll have fixes.....the bare minumum fixes absolutely minimum to get it out the door.
Make your games work offline
Reply 15 of 25, by Kenneth
It has been *confirmed* that a Russian company re-programed the games for XP.
It was also supposed to be Released October 11, 2005.
It is rumored that AGD Interactive's Kings Quest 1 VGA and 2 VGA will be in the Compilation.
And the Reason no Quest for Glory Compilation is announced yet is because simply, AGD is not done with QFGII Remake.
I do not know how much of that is true, except the Orginal Release date is true.
Other Compilations coming out:
Leisure Suit Larry
Space Quest
Police Quest.
They are most likely going to be CD Sleeves or DVD Cases.
More info:
http://www.vintage-sierra.com/forum/viewtopic.php?t=966
Besides Amazon, the Compilations are on Walmart - http://www.walmart.com/catalog/product.do?product_id=4307191
Looks like these Compilations are actually ESRB rated now. (This is recent). Strange that Space Quest is rated "E" when its older releaes were "T".
Reply 16 of 25, by DosFreak
I think my copy of KQ6 might be from the old KQ collection but I'm not sure. Anyway it seems to work.
Contents of Resource.cfg
videoDrv = VGA320.DRV
soundDrv = MT32.DRV
audioDrv = AUDBLAST.DRV
joyDrv = NO
kbdDrv = IBMKBD.DRV
mouseDrv = STDMOUSE.DRV
memoryDrv = ARM.DRV
mode = real
minHunk = 207k
language = 1
cmd = kq6cd
sync = .\
audio = .\
audioSize = 8K
cd = YES
List of files:
420.HEP
420.SCR
425.HEP
425.SCR
460.HEP
460.SCR
470.HEP
470.SCR
65535.MAP
ACTORS
ADL.DRV
AUDBLAST.DRV
AUDCDROM.DRV
AUDDISNY.DRV
AUDMSSYS.DRV
AUDNONE.DRV
AUDPRO.DRV
AUDPRO16.DRV
AUDPS1.DRV
AUDTHUND.DRV
GENMIDI.DRV
IBMKBD.DRV
IBMPS1.DRV
INSTALL.EXE
INSTALL.HLP
INSTALL.INI
INSTALL.INS
INSTALL.SCR
INSTALL.TXT
INTERP.ERR
INTERP.TXT
JOYSTICK.DRV
KQ6.ICO
KQ6.SYS
KQ6.WIN
KQ6CD
KQ6CD.BAT
MESSAGE.MAP
MICROSOF.DRV
MMAWARE.DLL
MT32.DRV
PKCOMP.INF
PROAUDIO.DRV
PROGLIB.DLL
RAVE.DLL
README
RESOURCE.000
RESOURCE.CFG
RESOURCE.MAP
RESOURCE.MSG
RESOURCE.SFX
SBPRO.DRV
SCIDLL.DLL
SCIWV.EXE
SIERRA.EXE
SIERRA.ICO
SIERRA.INI
SIERRAW.ICO
STD.DRV
VERSION
VGA320.DRV
VGA320BW.DRV
ACTORS subdirectory
ALEX.BIN
ALLARIA.BIN
ALLARIAD.BIN
BEAST.BIN
BEAUTESS.BIN
BEAUTPEA.BIN
BOOKSH.BIN
BOOKWORM.BIN
CALIPHID.BIN
CALIPHIM.BIN
CASSIMA.BIN
CELESTE.BIN
FERRYM.BIN
GNOMES.BIN
GRAHAM.BIN
HEADDRU.BIN
JOLLO.BIN
LAMPSELL.BIN
PAWNSHOP.BIN
PKCOMP.INF
PRINCE.BIN
ROSELLA.BIN
SALADIN.BIN
SIGHT.BIN
SMELL.BIN
SMELLNO.BIN
SOUND.BIN
SOUNDNO.BIN
TASTE.BIN
TOUCH.BIN
VALANICE.BIN
VIZIER.BIN
WINGG.BIN
Reply 17 of 25, by DosFreak
Here's the KQ6CD.BAT that I don't use (because it makes absolutely no sense....): (I just use sierra.exe)
@echo off cd \SIERRA\KQ6CD D: cd \ :getDisk2 if exist disk2 goto run echo Please Insert Disk 2 pause goto getDisk2 :run […]
@echo off
cd \SIERRA\KQ6CD
D:
cd \
:getDisk2
pause
goto getDisk2
:run
C:
sierra
Reply 18 of 25, by Kenneth
I think that Version 1 of Kings Quest 7 is whats on the Collection. This means it only runs on Windows. To run on DOS you need to copy a VESATEST.exe file from another (KQ7 was SCI2? Right?) SCI2 game. And then Make your own .BAT file which says:
@echo off call CheckCD F @if exist vesadrv.bat call vesadrv.bat K:\KQ7DOS\sierra -o K:\KQ7DOS\resource.cfg :end […]
@echo off
call CheckCD F
:end
Name it KQ7DOS.BAT
Make another Batch File:
F: cd vesa vesainst /Vvesa /BK:\KQ7DOS /TSIERRA.DIB cd\ K: […]
F:
cd vesa
cd\
K:
- Name it VESA.BAT
And your RESOURCE would look like this, Assuming F: is your CD ROM:
videoDrv = VESA.DRV soundDrv = MT32.DRV audioDrv = DACBLAST.DRV joyDrv = NO directory = \KQ7DOS cmd = KQ7DOS mouse […]
videoDrv = VESA.DRV
soundDrv = MT32.DRV
joyDrv = NO
directory = \KQ7DOS
cmd = KQ7DOS
mouseDrv = NONE
memoryDrv = NONE
minMemory = 1600k
brightness= 0
language = 1
minCPU = 386
CD = yes
resMap=F:;K:\KQ7DOS
resAUD=F:
resSFX=F:
patchDir=K:\KQ7DOS;F:;F:\AVI
robot=F:\AVI
In all of that K:\ Should be renamed to the directory KQ7 is in and F:\ is the CD-ROM.
Reply 19 of 25, by collector
Only the second collection had KQ7. It is the version 2 of the game, which runs on XP AND includes a DOS version. You cannot convert the Windows version of KQ7 to DOS.
I have all versions of KQ6 and they all run in DOSBox just fine. Even the Windows version will run in Win3x running in DOSBox.
