Reply 26220 of 57612, by jaZz_KCS
I bought another Yamaha Synth MIDI card, the SW1000XG, after I recently got the SW60XG.
I think I got the Yamaha-crave, please send help!
Reply 26221 of 57612, by Salient
Nice!
I just bought an SW1000XG as well (Paid 40 euros for it, which is a reasonable price I think).
Don't know when I will be putting it into use though, since I don't have a machine that I can install it in at the moment. 😀
Reply 26222 of 57612, by jaZz_KCS
To the questions at hand:
Salient wrote:
Nice!
Did you get the midi breakout cable with yours?
Did you - by any chance - get the SUPPORT CD with yours? Because the internet still lacks a proper image of that CD, I have searched far and wide. If you have it, it could be added t o the VOGONS Driver Database 😀
Reply 26223 of 57612, by brostenen
One of these....
For Amiga use, yet they can be used for music equipment if anyone know what they are doing.
https://www.ebay.com/itm/No-solder-ROM-switch … bD-bu:rk:1:pf:0
Reply 26224 of 57612, by Salient
I have actually still no Idea of the drivers and cables will be included. It should arrive today so I will reply here. The photo only showed the card, but on numerous occasions with other things the photo didn't show everything that came with them so there is still a chance.
Reply 26225 of 57612, by jaZz_KCS
Great. It's not so much about the very early drivers that are on them, as they are quite old and do not let the card run in multiclient mode, so in this case the newer drivers you can find on the net are actually better. But it's very much worth it for the metric shit tonne of sample songs that are on it, especially now due to the fact that XGCentral is long gone.
PS: Also there are a few other driver models on there as well which are a tad hard to find.
Reply 26226 of 57612, by Intel486dx33
appiah4 wrote:
My $30 486 set arrived: […]
I could have gone for another set with 8KB WB Am486-DX4/100 but that did not have a VLB IO card and came with just a VLB 5424.. I think this was the better deal (as I already had some WT i486 and Am486 DX4-100 parts but no DX4-75s)
Nice, I hope to build a 486dx-100 VLB build soon. I need to find the right motherboard.
What model is yours ?
Reply 26227 of 57612, by Windows9566
appiah4 wrote:
Windows9566 wrote:
both the bioses are pretty restricted, the hp one is a bit more than the gateway one
Can they be flashed to their non-oem Award/AMI/Phoenix BIOSes?
IDK, maybe not.
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Reply 26228 of 57612, by cyclone3d
I have this CD.. guessing it is the one you are looking for.
The attachment CD.jpg is no longer available
I'll image it and stick it on my repository and on vogonsdrivers.
I also have the MIDI breakout cable. Guessing you need the pinout?
EDIT:
The SW1000XG CD ISO and scanned CD label images are now on vogonsdrivers and on my XG repository.
http://www.vogonsdrivers.com/getfile.php?file … 469&menustate=0
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 26229 of 57612, by jaZz_KCS
Hopefully it wont have to come to this as the seller promised to look for the cable as he said it sounded familiar when I described it.
Nicely done adding the missing Support CD for the SW1000XG! 😁
Reply 26230 of 57612, by Salient
The card arrived in the meantime, but unfortunately it was indeed just the bare card, nothing extra came with it. 🙁
Reply 26231 of 57612, by appiah4
I have quite a few, I haven't completely decided on which one to use myself..
Octek Hippo VL+ DCA
ECS 486UL-1
Chicony CH-471A
PC Partner 486CV
(the one pictured above is the Chicony motherboard)
Reply 26232 of 57612, by appiah4
Likely the last two PCI sound cards I will need, I now have pretty much every chipset I would want to try.. (Well, except CS4624, for which I would happily buy a Terratec DMX XFire, but it's not a pressing matter as I have a Turtle Beach Santa Cruz with CS4630 which is basically a CS4624 but better..)
I had an Aureal 1 and an Aureal 2 card but no Aureal Advantage cards.. I understand these are better than 1 but worse than 2 and have more CPU overhead, so this will go into my P3-1000 Deskpro SFF PC to replace the FM-801 in there.. The FM-801 has better OPL3 for sure, but lacking A3D was a pain on my side..
I also lacked a YMF-7xx PCI sound card which I now have, albeit a cheap Chinese OEM.. Which got me wondering - what is the difference between a YFM-724 and a YMF-744 card?
Reply 26233 of 57612, by yawetaG
Erk...be sure to check whether that one actually uses a YMF-7xx chip, and not a CMI-87xx chip or similar with changed text on top of it. Some modern Chinese cards are fake and use rebranded chips from other manufacturers.
Reply 26234 of 57612, by appiah4
The packaging size (20mmx20mm) and pincount (144) are correct for a YMF-724; CMI-87xx cards are smaller in size and have less pins I believe. It's also an F revision (officially exists) and has an onboard AC97 codec.
Its gameport is probably not functional though, seeing as how unpopulated the PCB is.. Likely doesn't have high quality filtering either. It will do the job for testing purposes though.
Reply 26235 of 57612, by keropi
I bought very cheap this 486DLC system:
It came with a CT1350B (not suitable for CMS upgrade though, bummer) , a trident 8900C vga, a controller, 2x CF cards , a floppy and 8MB of ram.
The most interesting thing for me at this point was the 1993 motherboard that came with an AWARD 4.50 BIOS, had no idea you could find it in 386 systems.
The SARC chipset is just a rebranded UMC491 , got UMBs working fine with URAM.
When it boots you get this checks screen:
BIOS is the usual one
and speedsys results without an tweaking whatsever
This mobo was a pleasant surprise - if the CT1350B was a cms-capable one then this would be an unreal deal 😁 🤣
Reply 26236 of 57612, by jaZz_KCS
Nice system. Weird to see such an updated version of the Award BIOS on such an old board.
Speaking about unreal deals, I just scored this:
Please...send help. I keep on telling myself that it's ok, that it's just a christmas present from me to myself.
Reply 26237 of 57612, by cyclone3d
jaZz_KCS wrote:
Nice system. Weird to see such an updated version of the Award BIOS on such an old board. […]
So jelly! Awesome score!
YMF7x4 Guide
Reply 26238 of 57612, by bjwil1991
keropi wrote:
I bought very cheap this 486DLC system: […]
That is one cool system you got there.
Reply 26239 of 57612, by The Serpent Rider
That's infamous PCCHIPS though.
