Reply 100 of 106, by Ozzuneoj
- l33t
wrote:Moreover the SBPro2 CT1600 (07 and 08), and the two CT2600 revisions (01 and 02), all from 1993-1994 have the same revised PCB layout and are very quiet cards.
Is there any noticeable difference between the 03, 06 and CT1690 rev 02? I have one rev 3, two rev 6 and one CT1690 rev 2 and I'm trying to decide which one to keep.
As mentioned earlier in the thread, the 03 has no crystal, but the others all have them. Have we determined if there is any actual compatibility difference with the crystal?
The 03 has CT1336, but there is apparently no difference between that and the CT1336A (EDIT: On the SB Pro2) ?
Its crazy how much variation there is with these things. One of my rev 6 cards has an older through hole ceramic cap more commonly found on the very old devices (the tall, flat, two legged ceramic caps) and the CT1336A has the old angled creative logo. Compare this to the other rev 6 I have with the more "modern" cylinder type ceramic cap and the more plain, more modern printing on the CT1336A (almost looks more like a Vibra at first glance). The 03 has no through hole ceramics at all but has the older style logo on the CT1336 and older font on the label on the back. To add further confusion, the CT1690 (dated 1993... compared to 91 and 92 on the others) also has the older style ceramic cap and the angled logo on the CT1336A.
I used sbcheck to look at the dsp version too. Both rev 6 cards and the ct1690 rev 2 have DSP version 3.02, the rev 3 has DSP version 3.01.
Is there any difference between these DSP versions? Why would they update it if there was no difference?
