First post, by lordskylark
Hello,
I need one of these for MT-32 and one for SC-55:
Does someone have a .mid file containg all the appropriate messages to reset the device to 100% default settings, including default panning, instruments, volume levels, etc?
Thanks,
Andrew
Reply 1 of 17, by gdjacobs
Run this with any MIDI playback tool.
Reply 2 of 17, by lordskylark
Will that work with both MT-32 and SC-55? (I couldn't find any info if it was the same.)
Reply 3 of 17, by lordskylark
When I run that, it doesn't reset the MT-32 to default panning and default instrument settings (and probably more). Is there something that does that?
Reply 4 of 17, by keropi
Here you go, dedicated reset SysEx files for LA (mt32/cm32l and similar) , GS, GM and XG devices. Just run the .bat you want
https://www.mediafire.com/file/7byybmo927c1xb … resets.zip/file
Reply 5 of 17, by lordskylark
Is there any way to input that information into a midi itself?
Reply 7 of 17, by lordskylark
I'm trying to record 7 hours worth of midi (I don't want to sit there for 7 hours to reset each time - in fact, I need to do it 9 times, because I want each channel recorded independently primarily to avoid all polysnyth problems - according to munt, some songs have 100 partials even though they are MT-32 songs, and no MT-32 can play it correctly as a whole), but the program itself needs that information in the midi itself. And each midi needs a full reset beforehand, because some midis use set pan, volume, etc. but others use default MT-32 panning, etc, so it's needs to be reset before each midi otherwise the program keeps using the pan and volume, etc. settings from the previous midi.
Can someone provide a midi file with all the commands necessary for the MT-32 to have a complete reset. And then one for SC-55? Then I can drop it between every single midi.
Reply 8 of 17, by gdjacobs
My bad, I didn't read your message as closely as I should have. The MIDI file I provided stops all playback but doesn't reset the device configuration. So, LA devices will still have custom instruments loaded and all devices will preserve custom effects settings.
Why not do something like this?
DOSMID %MIDIDIR%\file1.mid
GM-RESET
DOSMID %MIDIDIR%\file2.mid
LA-RESET
Put it all in a batch file.
Reply 9 of 17, by lordskylark
I need to use the DAW in order to make sure that all the channels are lined-up 100% when recording. Otherwise, doing something like that, I would have to manually keep lining up 9 channels (probably not always precise enough) and the time would be far too consuming I think.
Reply 11 of 17, by Falcosoft
Here are 2 mid files that do the MT-32/GS reset for you. Both contain 200ms delay after the reset.
The attachment GS_MT32_Reset.zip is no longer available
Website, Youtube
VST Midi Driver Midi Mapper
Reply 12 of 17, by lordskylark
GS_MT32_Reset.zip
Thank you very much for your time involved in this.
Am I supposed to use both for both soundcards, or is the MT-32 to use the MT-32 one ONLY and the SC-55 to use the GS ONLY?
Thanks,
Andrew
Reply 13 of 17, by Falcosoft
lordskylark wrote:
Thank you very much for your time involved in this. Am I supposed to use both for both soundcards, or is the MT-32 to use the MT […]
Thanks,
Andrew
MT-32 reset is only for MT-32 and GS reset is only for your SC-55.
Website, Youtube
Reply 14 of 17, by lordskylark
Thanks,
Andrew
Thanks, I will hopefully get a chance to try it out this week and see how it works.
Is there something specific in the manual that gives 100% detail of what is reset in a system reset?
For example in the manual, I see a list of default instruments, their panning, their volume, etc. Is there anything else?
Reply 15 of 17, by Falcosoft
Usually no such detailed lists exist in manuals maybe because a 'Reset' resets everything (that has a default value).
Yes, there are many more.
E.g.
1. All notes/sounds set to off.
2. Master volume, balance, tuning etc. are set to default.
3. All effects/effect parameters are set to default (e.g. Reverb presets such as Room, Hall etc.)
4. All Common Controllers are set to default values on all channels(Modulation, Volume, Pan, Expression, Sustain, Reverb, Chorus etc.)
5. All Pitch Bend ranges are set to default semitones on all channels.
6. All NRPN's are set to default on all channels.
7. All Banks/Instruments are set to default on all channels.
8. Other things I do not recall just now 😀
The more features a synth supports, the more are set to default by a reset.
Website, Youtube
Reply 17 of 17, by keropi
Kahenraz wrote on 2022-01-17, 01:37:
Is there a 32-bit version of this DUMP.EXE which can run on Windows?
Surely there is some windows tool as well - I just don't know about it , tbh I only "care" about the DOS side of things when it comes to midi , mpus, soundcards etc
Pretty sure someone will suggest a tool 😀
