Reply 26320 of 52939, by appiah4
I know there are blank ones; though not cheap they are also not very expensive and with a dremel you can easily cut out an AT keyboard hole on those. What I really need are those early ATX backplates though, never saw them around for sale..
Reply 26321 of 52939, by cyclone3d
The blank ones are very cheap at less that $1 a piece shipped:
https://www.ebay.com/itm/2PCS-I-O-shield-no-a … HU/362472821364 - $1.87 for 2 shipped from China.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 26322 of 52939, by arncht
Originally the backplate was the part of the case, later comes the mainboards with own backplate. So be careful with the early atx cases and their backplates - it is possible, they are unique.
Overdoze of the demoscene
Reply 26323 of 52939, by BeginnerGuy
Do cameras count? I just bought a Sony Mavica FD87. Couldn't resist because I need floppies and the seller seems to be including a 40 pack of sealed 1.44mb disks with it and they are so pricey to get new on ebay. Won the auction for $14.65 after shipping so I'm pleased enough. Looking forward to taking 640x480 dog pics with a crappy old lens.
If anybody knows a cheaper way to acquire bulk unused disks that are preferably not neon, I'm all ears.
202.56 KiB
Sup. I like computers. Are you a computer?
Reply 26324 of 52939, by appiah4
Grabbed four of them. I have a dremel to cut out AT Holes as I please, these should come in handy.
Reply 26325 of 52939, by Intel486dx33
The attachment s-l1600.jpg is no longer available
I bought a Sony Mavic too last month. Mine came with a pack of floppies too.
Nice Camera's.
    265.9 KiB
Reply 26326 of 52939, by appiah4
This lot was on sale for less than $5 so I grabbed it. Appears to be an Elpina M537D (VX_Pro+) V5.2 (how much memory can the VXPro+ i.e. VIA VPX cache?). The motherboard is sold as not working, which is not surprising as it is missing two caps market purple, and one component seems to be partially torn off (marked red). Can anyone tell me what the red marked component is called, how I can determine its rating and whether it can be fixed or replaced?
262.83 KiB
The soundcard is a chipset I didn't have before (Zoltrix Audio Plus 6400 3D PnP V.5 AV310 - I already have the AV309 version with CS4232, but this one appears to be the AV310 version with CMI8330)
Reply 26327 of 52939, by tayyare
PCChips, eh? 🤣 From the same guy?
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 26328 of 52939, by Emu10k1
That red encircled component is a "Choke coil inductor". You could replace it with another with the same number of spires and diameter, but it seems that you could just solder it in place again as it doesnt seems to be damaged.
Reply 26329 of 52939, by arncht
do not invest to much time to the pcchips and the vxpro stuff 😀
http://redhill.net.au/b/b-bad.html
Reply 26330 of 52939, by Thallanor
Nice Camera's.
Then post a picture of your own and not a stock image FFS.
Got a new pet last week.
19.54 KiB
Reply 26331 of 52939, by appiah4
Nah, not the same guy, some other dude. The motherboard is an Elpina M537D (VX_Pro+) V5.2, not PCChips.
Also got these in the mail today:
ASUS-AGP-V2740-TV-Intel.jpg Keropi-Music-Quest-Clone-Intelligent-MPU-401-Card.jpg
Intel i740 VIVO and a Music Quest MPU-401 card by keropi
Reply 26332 of 52939, by TheMobRules
Elpina M537D == PCChips M537
It's the legendary VXPro that many of us owned back then because it was basically the cheapest Socket 7 around.
Reply 26333 of 52939, by liqmat
Thallanor wrote:
Then post a picture of your own and not a stock image FFS. […]
Nice Camera's.
21.76 KiB
Beautiful! What breeder?
This is my cat being playful. Such a silly one.
43.67 KiB
Reply 26334 of 52939, by liqmat
arncht wrote:
The attachment VXPRO+.jpg is no longer available
I believe I have a fine example of what you speak. Too bad, as I like the white ISA slots and it runs rather well other than one 72-pin memory clip is broken. Even has an AMD DX2/80 in it. It does have the suspicious cache chips, the soldered BIOS chip and the blank chipset though.
1.02 MiB
736.63 KiB
756.52 KiB
Reply 26335 of 52939, by bjwil1991
I had almost the exact motherboard between 1994 and 2012 that had real L2 cache and an AMD AM486-DX4 120 CPU in it. That was a beast, until the BIOS chip died (Award, aka, the "Y2K bug" BIOS that was on a PROM chip).
PCChips M912 v1.7 with fake L2 cache
You can, however, desolder the fake L2 cache, remove the solder leads that serves as the L2 cache size and make it into a motherboard with real L2 cache:
PCChips M912 v1.7 with real L2 cache
And, if needed, you can desolder the BIOS chip carefully and purchase an IC socket like this: https://www.digikey.com/product-detail/en/on- … 53-5-ND/4147603 (Digikey part number: ED3053-5-ND).
Also, I found a SIMM-72 slot: https://www.digikey.com/product-detail/en/te- … 4049-ND/1639981 (Digikey part number: A114049-ND) in case you're interested as well.
Reply 26336 of 52939, by tayyare
appiah4 wrote:
...The motherboard is an Elpina M537D (VX_Pro+) V5.2, not PCChips.
Elpina Vx Pro but not PCChips? You need to repeat your PCChips 101, because you just failed 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 26337 of 52939, by DaveJustDave
So i picked up a PS/1 (another one). I already had a 386 one, but wanted the original 286 one. dallas RTC is dead as expected and the floppy is malfunctioning, but it's a nice system to have.
ordinarily, not a big deal. however, see if you can spot what it came with.
185.89 KiB
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 26338 of 52939, by liqmat
bjwil1991 wrote:
I had almost the exact motherboard between 1994 and 2012 that had real L2 cache and an AMD AM486-DX4 120 CPU in it. That was a b […]
Oh no sir, this will be going on the hardware giveaway thread since it works fine and someone might like a project like what you speak of.
Reply 26339 of 52939, by brostenen
liqmat wrote:
Beautiful! What breeder? […]
Nice Camera's.
HUH' 😳 What?
